Author Topic: POLARANG and SNAPSTYL  (Read 2829 times)
StykFacE
« on: January 23, 2008, 12:00:09 PM »
Trying to do a quick LISP file to set my Snap/Polar Angle settings on the fly for when I do ISOMETRIC drawings. I figured it would be extremely simple, but guess not. Need a little advice:
(defun C:ISO (/)
    (set POLARANG 30)
    (set SNAPSTYL 1)
Figured this would be all I needed to do... What am I missing? Thanks gusy.  :kewl:
Guest
Re: POLARANG and SNAPSTYL
« Reply #1 on: January 23, 2008, 12:07:05 PM »
set should be setvar   :wink:
StykFacE
« Reply #2 on: January 23, 2008, 12:27:37 PM »
Ah, forgot about that one. Got it, but it makes my Polar Angle 278.8733853924698. Any idea?
Updated code:
(defun C:ISO (/)
    (setvar "POLARANG" 30)
    (setvar "SNAPSTYL" 1)
Guest
« Reply #3 on: January 23, 2008, 12:30:40 PM »
Right off the top of my head, not sure.
But you can change it to (command "polarang" "30") and it will work.
*runs off to research polarang*
StykFacE
« Reply #4 on: January 23, 2008, 12:35:06 PM »
awesome Matt thanks again bud!! worked perfect. ;-)
Guest
« Reply #5 on: January 23, 2008, 12:43:23 PM »
You're welcome.
And I found that POLARANG is in radians, not degrees.  So doing (setvar "polarang"
(defun DegreesToRadians (numberOfDegrees)
   (* pi (/ numberOfDegrees 180.0))
(defun C:ISO (/)
   (setvar "POLARANG" (DegreesToRadians 30))
