Author Topic: trimed hatchs recover  (Read 1565 times)
dussla
« on: December 06, 2007, 02:20:43 AM »
i got  some plans
but i can see  trimed hatch with objects
----ob  --              -------------
----ject --       ->   -------------
i would like to rewind  trimed hatch to orginal hatch (=no trims)
can you understand my explain ?
thank you good answer and good friends always
« Last Edit: December 06, 2007, 09:35:39 AM by dussla »
Re: trimed hatchs recover
« Reply #1 on: December 06, 2007, 09:51:43 AM »
There is a routine to recreate the hatch border. Use it & delete the hatch. Then re-hatch the border only.
CADaver
« Reply #2 on: December 06, 2007, 01:05:23 PM »
Is the hatch still associative? Use HATCHEDIT.
Krushert
  • FREE BEER Tomorrow!!
« Reply #3 on: December 06, 2007, 01:29:48 PM »
What version are using?  I noticed it in R2007
Select the hatch and right click.(if you have context menu as your right click option)
you have see a command called generate hatch boundary.
there are other some other hatch editing options there.
