Author Topic: Panning switches Autocad off  (Read 8912 times)
McRojo the Irishman
« Reply #15 on: August 03, 2004, 03:15:34 PM »
Isn't that where the restaurant at the end of the universe is located?
VerticalMojo
« Reply #16 on: August 03, 2004, 03:57:48 PM »
Quote from: Kate M
Love the new avatar, Mojo. :-) Where'd you find it?
Thanks Kate… Got it @ http://www.cognitivedistortion.com/..... It was a wallpaper but I cropped out the part I wanted..... If you look under user submittals then you can find some nice little gems!
Heres what it looked like as a wallpaper....
Shaaa, I was like whoa dude...
42
« Reply #17 on: August 04, 2004, 04:24:39 PM »
McRojo the Irishman wrote
Very very close it is actually Diffuse Nebula M42 (NGC 1976), an emission and reflection nebula, in Orion.
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
pmvliet
« Reply #18 on: August 05, 2004, 08:10:46 PM »
We have a situation here where sometimes a user goes to hatch some linework and poof there is goes. We also have times when a user goes to change properties of some entities and poof, there sit's your desktop.
Change properties like layers where they grip the entities and then go to the layer pull-down. I myself set to current layer then match to current layer and I won't get that problem. I tell them don't do it that way but do they listen... It can be predictable and several times I have threatened to psot the drawings here to see if others get the same poof...
Pieter
