Author Topic: Copy Attributes  (Read 3843 times)
VerticalMojo
Copy Attributes
« on: March 22, 2004, 04:37:07 PM »
Maybe you guys knew this (im sure you do) but I thought I would share whatever I discover cause I didn't......
On a block if you select a attribute by its grip point, hold down the shift key and you can copy it. The attribute is associated with the block but you wouldn't see it when you edit the block unless you select to edit that particular attribute. It could be helpful if more info is needed to be put on that block and you don't want to redefine it. :wink:
Copy Attributes
« Reply #1 on: March 22, 2004, 04:52:50 PM »
Um.... actually what you are doing is copying the block along with it's attributes. So you in fact have 2 blocks and double the attributes.
Sorry to burst your bubble there....
VerticalMojo
Copy Attributes
« Reply #2 on: March 22, 2004, 05:15:11 PM »
I just figured that out keith.... and your right. :oops:
Copy Attributes
« Reply #3 on: March 22, 2004, 05:44:11 PM »
no problem...I tried it out in several different ways just to be sure I wasn't missing something....
hyposmurf
Copy Attributes
« Reply #4 on: March 22, 2004, 05:44:52 PM »
Its usually the CTRL though in the default set up,that hit while dragging a block to copy it.You notice that a little + appears when u hit the CTRL key,but hit the shift key while holding donw the CTRL key as well and a arrow appears.What on earth does this mean? :?
Copy Attributes
« Reply #5 on: March 22, 2004, 05:51:57 PM »
I think it's for "move".
VerticalMojo
Copy Attributes
« Reply #6 on: March 22, 2004, 05:53:42 PM »
That would be cool if you could do that....... copy the attribute that is.
hyposmurf
Copy Attributes
« Reply #7 on: March 22, 2004, 05:54:27 PM »
Could be,bit pontless though you dont even need to hold down shift or CTRL to move the block just drag it.V Mojo the attribute does copy along with the block though.
VerticalMojo
Copy Attributes
« Reply #8 on: March 23, 2004, 10:10:26 AM »
At least now I know you could copy multiple by doing this. It works for anything......
Copy Attributes
« Reply #9 on: March 23, 2004, 11:14:21 AM »
Well, you could always refedit the block, copy the attribute, then attsync the blocks and the attribute will be added to all of the blocks with that name.
You will have to then edit the attribute to add the value, but if you set the value of the attribute to be preset, it should enter that value in all of the blocks
