Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help volume from contours
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help volume from contours (Read 1022 times)
mhy3sx
Newt
on:
July 01, 2023, 10:04:52 AM »
can any one help me to fix this code
Code - Auto/Visual Lisp:
[Select]
defun
c:test2
_foo _rtos a b r s v tbl
defun
_foo
e
list
vlax-curve-getarea
e
cdr
assoc
38
entget
e
defun
_rtos
n
rtos
n
2
2
setq
tbl
vlax
make
safearray
vlax-vbDouble
cons
1
6
cond
and
setq
s
ssget
0
"*polyline"
4
70
1
setq
s
vl
remove
if
listp
mapcar
cadr
ssnamex
s
setq
s
mapcar
'_foo s
setq
s
vl-sort
s '
lambda
r j
car
r
car
j
setq
row
0
vlax-for
val s
setq
a
car
val
b
cadr
val
;; calculate the results
setq
A1
car
a
A2
car
b
Dh
abs
cadr
a
cadr
b
sum
A1 A2
Dh
0.50
V
A1 Dh
0.50
;; insert the results in table
vla
put
value tbl
vlax
make
safearray
index
list
setq
row
1+
row
0
A1
vla
put
value tbl
vlax
make
safearray
index
list
row
1
A2
vla
put
value tbl
vlax
make
safearray
index
list
row
2
Dh
vla
put
value tbl
vlax
make
safearray
index
list
row
3
sum
vla
put
value tbl
vlax
make
safearray
index
list
row
4
V
;; print table
princ
"Elevation A1 A2 Dh (A1+A2) x Dh x 0.50 V"
setq
row
0
while
setq
row
1+
row
vla
get
dim2 tbl
1
setq
A1
vla-get-value
tbl
vlax
make
safearray
index
list
row
0
A2
vla-get-value
tbl
vlax
make
safearray
index
list
row
1
Dh
vla-get-value
tbl
vlax
make
safearray
index
list
row
2
sum
vla-get-value
tbl
vlax
make
safearray
index
list
row
3
V
vla-get-value
tbl
vlax
make
safearray
index
list
row
4
princ
strcat
\n
_rtos A1
_rtos A2
_rtos Dh
_rtos sum
_rtos V
princ
Logged
DEVITG
Bull Frog
Re: Help volume from contours
Reply #1 on:
July 13, 2023, 04:06:20 PM »
@mhy3sx. please upload the lost defund
vlax-make-safearray-index
Logged
Location @ Córdoba Argentina Using ACAD 2019 at Window 10
ribarm
Gator
Marko Ribar, architect
WWW
Reply #2 on:
July 14, 2023, 02:26:08 AM »
I could be wrong, but I suspect that missing functions look like this :
[Select]
defun
vlax
make
safearray
index
lst
vlax-safearray-fill
lst
defun
vla
get
dim2
a b
safearray-get-dim
a
b
Last Edit: July 14, 2023, 03:15:20 AM by ribarm
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
