Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Layer Filters
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Layer Filters (Read 1144 times)
MSTG007
Gator
I can't remeber what I already asked! I need help!
Layer Filters
on:
January 09, 2014, 09:38:21 AM »
Is there a way to turn on/off and freeze/thaw a layer filter group that is already setup in a drawing by either a script or lisp?
Lets say I have the following filters:
A
B
C
D
Is there a way to just either turn off A and C Layers?
thanks!
Logged
Civil3D 2020
rkmcswain
Swamp Rat
WWW
Re: Layer Filters
Reply #1 on:
January 09, 2014, 01:20:16 PM »
AFAIK, the list of layers that meet the criteria of a given filter is not stored anywhere, only the layer filter definition is stored.
So IF (and that is a big IF) your layer filter is simple and only filters by layer name, then you could use the code in post #7 (here:
http://www.cadtutor.net/forum/showthread.php?61032-Layer-Properties-Filters&p=414430&viewfull=1#post414430
) and then drill your way down to the layer filter definition, then use that string in a command line LAYER FREEZE (or THAW) command since that will accept wildcards.
I *think* that if your layer filters are more complex than that, you'll have to gather the filter properties and iterate the layer list yourself building a list of layers to freeze/thaw.
Logged
R.K. McSwain
twitter
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
Layer Filters
