With regard to that, when you get the results, depending on what your doing you may have to interpolate the result. As an example, Lee posted some code for selecting a particular object, which when I dumped the object, it was AcDbText. Lee's routine was looking for the type, which turned out to be "Text" (DXF code 0).
