I am updating some company tool palettes. Some are for text items and some are for using the qleader command. In some cases, the same item might need both tools.
Is there a way to place both MTEXT and QLEADER icons on one flyout? I seem to be limited in what can go on a tool palette flyout. So far, it seems that somewhere, there is a group of flyout palettes or panels pre-defined and you can enable or disable individual icons within a tool palette item, but I see no way to add other commands to the group of icons in the flyout.
TIA
