Controls object highlighting; does not affect objects selected with grips. 0Turns off object selection highlighting1Turns on object selection highlighting
Controls the display of selection previewing Objects are highlighted when the pickbox cursor rolls over them. This selection previewing indicates that the object would be selected if you clicked. The setting is stored as a bitcode using the sum of the following values: 0Off 1On when no commands are active 2On when a command prompts for object selection
