One macro is the typical that comes with CAD.
Here is the modified one that replaces an OLD Revdate with a new Modified one. -
^C^C_oleframe;0;draworder;all;;f;oleframe;2;^C^C_-osnap;off;_z;extents;^C^C_-layer;unlock;title_block;;_line;15.9,6.815;15.9,.65;;_erase;16,9.8;15.7,.25;;^C^C^_-layer;n;tb_text;m;tb_text;;-PURGE;a;;n;_-PURGE;a;;n;_-PURGE;a;;n;_-insert;revdate;15.76,0;;;90;_revdate;-layer;m;0;;^C^C_z;extents;-layer;lock;title_block;;
The newer version of the Revdate has the entities moved a little closer to each other. Her problem seems to use the original. BUT, I have search her machine as well as our server for another Revdate Block and found only the one we are supposed to use.
