Author Topic: Trying to change block color  (Read 2606 times)
Proctor
« on: May 29, 2008, 03:51:29 PM »
Hello:
I'm creating new block and then trying to change it's color before inserting into modelspace. After it's created, it's propterties show that the color is correct; however, it does not appear to be correct by looking at it in modelspace.
    <CommandMethod("addcircle")> _
    Public Sub AddNewBTRB()
        Dim myTransMan As DatabaseServices.TransactionManager
        Dim myTrans As DatabaseServices.Transaction
        Dim myDwg As Document
        Dim myBT As BlockTable
        Dim myBTR As BlockTableRecord
        myDwg = Application.DocumentManager.MdiActiveDocument
        myTransMan = myDwg.TransactionManager
        myTrans = myTransMan.StartTransaction
        'Open the database for Write
        myBT = myDwg.Database.BlockTableId.GetObject(Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
        'Add a new BlockTableRecord
        myBTR = New BlockTableRecord
        myBTR.Name = "CircleBlock"
        'Draw to the Block
        myBTR.AppendEntity(New DatabaseServices.Circle( _
            New Geometry.Point3d(0, 0, 0), New Geometry.Vector3d(0, 0, 1), 1.5))
        myBT.Add(myBTR)
        'Commit the Transaction
        myTrans.AddNewlyCreatedDBObject(myBTR, True)
        myTrans.Commit()
        'Dispose of the Transaction Objects
        myTrans.Dispose()
        myTransMan.Dispose()
    End Sub
    <CommandMethod("insertcircle")> _
       Public Sub InsertBlockB()
        myBT = myDwg.Database.BlockTableId.GetObject(Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead)
        myBTR = myBT(BlockTableRecord.ModelSpace).GetObject(Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
        'Insert the Block
        Dim myBlockRef As New DatabaseServices.BlockReference( _
            New Geometry.Point3d(2, 3, 0), myBT("CircleBlock"))
        myBlockRef.Rotation = 45 * Math.PI / 180
[color=red]        myBlockRef.Color = Colors.Color.FromRgb(200, 0, 200)[/color]
        myBTR.AppendEntity(myBlockRef)
        myTrans.AddNewlyCreatedDBObject(myBlockRef, True)
        myTrans.Commit()
        myTrans.Dispose()
    End Sub
I don't know what I'm doing wrong.
Thank you for your help,
Proctor
Re: Trying to change block color
« Reply #1 on: May 29, 2008, 03:56:07 PM »
Perhaps the author of the code could help you.
... abd an acknowledgement wouldn't go astray either.
Proctor
« Reply #2 on: May 29, 2008, 03:58:40 PM »
Hi Kerry:
Gee Wiz...you're right...
...code compliments of Jerry Winters.
« Reply #3 on: May 29, 2008, 04:07:22 PM »
AFAIK, all items written to a block are treated as having been placed on the current layer with the current color. Thus the circle in the block would likely not be set to layer 0 or the color to byblock, causing the circle to inherit the color layer it was created on. You should set the layer property of the nested objects to 0 and/or set the color property of the objects to byblock, then it should inherit the color properties of the block.
Glenn R
« Reply #4 on: May 29, 2008, 04:14:33 PM »
Look up SetDatabaseDefaults() - you should generally use this when adding entities
Glenn R
« Reply #5 on: May 29, 2008, 04:16:43 PM »
Also if you're changing the colour of the Block reference itself, you will only notice the changes if the entities inside the block are defined with colour etc. as bylayer, or more importantly, byblock.
Glenn R
« Reply #6 on: May 29, 2008, 04:17:20 PM »
...it goes without saying that this will only work for entities on layer 0.....
Proctor
« Reply #7 on: May 29, 2008, 05:16:39 PM »
Thanks so much for your help....got it to work!!!  Because I'm so new at this...sometimes I'll use the snippets from Jerry's book first; after which, I customize it from there.  I'm going need to create a new layer before adding my blocks..so I also added that into the code below and now it works just like I need it.
Setting the color of the object used to create the block before creating the block is what I needed to do.
Thanks to all for your help!!!
Proctor
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument()
        Dim ed As Editor = doc.Editor
        'add new layer here:
        Dim curdb As Database = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
        Using docLock As DocumentLock = ed.Document.LockDocument()
            Using trans As Transaction = ed.Document.TransactionManager.StartTransaction()
                Dim lt As LayerTable = CType(trans.GetObject(curdb.LayerTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite), LayerTable)
                Dim x As New LayerTableRecord
                myLayerName = "6 PER FT"
                With x
                    .Name = myLayerName
                    .IsOff = False
                    .IsFrozen = False
                    .IsLocked = False
                    lt.Add(x)
                    trans.AddNewlyCreatedDBObject(x, True)
                End With
                Dim CenterPoint As New Geometry.Point3d(0, 0, 0)
                Dim myCircle As New DatabaseServices.Circle(CenterPoint, New Geometry.Vector3d(0, 0, 1), 1.5)
                myCircle.Color = Colors.Color.FromRgb(200, 0, 200)
                'Draw to the Block
                myBTR.AppendEntity(myCircle)
                myBT.Add(myBTR)
                trans.AddNewlyCreatedDBObject(myBTR, True)
                trans.Commit()
            End Using
        End Using
    End Sub
        Dim db As Database = HostApplicationServices.WorkingDatabase
        'Insert the Block
        myBlockRef.Layer = myLayerName
        myTrans.Commit()
        myTrans.Dispose()
    End Sub
