Author Topic: Transparent Solid Hatching  (Read 2446 times)
bmossman
« on: April 03, 2008, 09:55:31 AM »
When plotting, Is there a way to make solid hatching semi transparent so that an image beneath is visible?
Re: Transparent Solid Hatching
« Reply #1 on: April 03, 2008, 10:03:36 AM »
use 95% screen, or 5% whichever gives a lighter fill
bmossman
« Reply #2 on: April 03, 2008, 10:13:20 AM »
All that does is lessen the intensity of the color...doesn't make it transparent.
« Reply #3 on: April 03, 2008, 10:19:20 AM »
Me thinks you will want to turn those hatch areas OFF that you want to not plot before you do (plot) and then they will be transparent.
alanjt
  • Standby for witty remark...
« Reply #4 on: April 03, 2008, 10:20:08 AM »
could you use a dot hatch and just set it to a high count for a hatch scale?
i'm sure i'm just being retarded, but anything is better than nothing.
Dropbox
Willie
  • Going nowhere slowly
« Reply #5 on: April 03, 2008, 10:27:15 AM »
Yep,  Dot hatch is your best option.
Solid can't be transparent like in ArcGIS 9
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Rob...
« Reply #6 on: April 03, 2008, 11:06:00 AM »
I use solid hatching with shading applied and send it to the back using display order.
CAD Tech
Bob Wahr
« Reply #7 on: April 03, 2008, 12:05:11 PM »
I think if you edit your PC3 and set the line merging under graphics to merge instead of overwrite, it will do it.  Not 100% sure that's true with jamaican pictures but give it a shot.
craigr
« Reply #8 on: April 03, 2008, 12:51:34 PM »
^^^^  -  That's how I do it...
craigr
bmossman
« Reply #9 on: April 03, 2008, 01:05:14 PM »
That worked, however it made my computer smoke :-D
