Author Topic: VLX to lisp  (Read 21844 times)
TJAM51
VLX to lisp
« on: January 08, 2008, 01:06:13 PM »
Can VLX be converted to LISP?
deegeecees
Re: VLX to lisp
« Reply #1 on: January 08, 2008, 01:10:33 PM »
Try a Google on "VLX decompiler".
I believe they have tried to discourage that sort of thing.
rkmcswain
Re: VLX to lisp
« Reply #2 on: January 08, 2008, 03:36:43 PM »
Not sure about VLX, but FAS can. I'm not encouraging it, I'm just saying I have seen it done.
Re: VLX to lisp
« Reply #3 on: January 08, 2008, 03:58:02 PM »
Nah, neither can be "decompiled". That project was dropped.  It was very cool info that guy provided though.
rkmcswain
Re: VLX to lisp
« Reply #4 on: January 09, 2008, 08:06:46 AM »
Yes, FAS can be "decompiled". To repeat, I have seen it done.
Re: VLX to lisp
« Reply #5 on: January 09, 2008, 08:53:03 AM »
Dude, the .fas format isnt really `compiled' so it cant be `decompiled'. The .fas format can only be "decrypted". ...Look in to it.
Now, like i said; there isnt a "tool" out there that i know of right now but the info is so people can build their own if they want. All the tools ive used were very rudimentary; you can do almost the same with a hex editor and a little snooping.
rkmcswain
Re: VLX to lisp
« Reply #6 on: January 09, 2008, 01:24:07 PM »
Whatever, you are talking semantics now.
Quote from: Se7en
The original question wasn't "is there a tool?" - the question was "can it be done?"
BTW: Who is this "guy" that you are talking about?
Re: VLX to lisp
« Reply #7 on: January 09, 2008, 01:48:49 PM »
Im talking about ``Dead_loop''.
Awhile back a guy posted on the news groups that he wanted to create a fas/vlx decompiler...
[ http://groups.google.com/group/autodesk.autocad.customization/msg/28e66efc1e0bb99d ]
Needless to say, this topic soon got deleted along with his notes/tools.
No tool? then use a hex editor.
Tom
Re: VLX to lisp
« Reply #8 on: January 09, 2008, 04:40:39 PM »
If you google the right words you will find that not only is ther a "tool"
to decompile/decrypted/dissasemble fas files it will also decompile/decrypted/dissasemble vlx
into fairly readable code
its not something I would endorse But the fact is there is a way to convert a vlx to lisp
Re: VLX to lisp
« Reply #9 on: January 09, 2008, 06:07:52 PM »
Have you used it?
Ive taken a look at a fas and vlx file and i noticed that there is basically no difference between a vlx and a fas file. The only difference is a small ``header'' or ``make file'' included in the vlx.
I will delve a bit deeper later.
