Okay, here is one that is puzzling us. We have a subdivision that we are working on that has a roadway that resembles a "P"
Assume you are starting your stationing at the bottom of the "P", when C3D hits the first intersection, it turns right and stations on around that way. We would like to have the stationing travel all the way up the back of the "P" and then around. We couldn't figure out how to do this. In Terramodel, it was quite easy to do. I ended up having to recreate the centerline geometry for this portion and leave a gap. I applied the stationing, then went in and extended the line to meet the back of the "P". Is there an easier way to do this? Thanks everyone!
