When I have a wire (Line) go thru text, I typically draw horizontal lines at the top and bottom of the text then offset it .03, then trim the wire between those 2 offset lines.
I noticed that I CAN do a trim from the text, but it doesn't trim to the distance that I want.
Is there a setting that controls this distance?
craigr
