Author Topic: xref layer name conversion  (Read 10905 times)
Re: xref layer name conversion
« Reply #15 on: March 28, 2006, 03:26:13 PM »
For fun I benched all the variants --
Woooowhoooooo!!!
Mine was the slowest, but it was still something I just learned, so I thought it would be fun to post it.
Is this typical of recursive programs?  or was this a bad example?  Sorry for the thread hijacking.. :cry:
« Reply #16 on: March 28, 2006, 06:29:07 PM »
Edit: Fixed typo in MP_StripPrefixRecEx.
As I noted in another thread, recursive functions typically represent convenience for the programmer, but more work for the computer.
Optimizing recursive functions is a big topic Tim, and not one I'm particularly qualified to author, but I would say that when writing recursive functions some of the things you have to do are eliminate redundant function calls and variable declarations.
For example -- pretending that vl-string-position doesn't have the optional "start from the end" argument let's write a recursive variant that employs a common technique: write core (recursive) functionality as a function that is initially invoked via a wrapper --
(defun MP_StripPrefixRecEx ( string code )
    ;;  Not to be called directly, only via wrapper
    ;;  function MP_StripPrefixRec.
    ;;  Uses argument 'code' which is calculated
    ;;  using the ascii function only once, by the
    ;;  calling / parent code.
    ;;  Uses global scope variable 'position' declared
    ;;  by the calling code (or fully global if the
    ;;  parent code does not declare said variable),
    ;;  so it doen't have to push more onto the stack
    ;;  with each successive iteration than is absolutely
    ;;  esssential.
    (if (setq position (vl-string-position code string))
        (MP_StripPrefixRecEx
            (substr string (+ 2 position))
            code
        String
(defun MP_StripPrefixRec ( string delim / position )
    ;;  I am the wrapper code, responsible for doing any
    ;;  preprocessing, e.g. the (ascii delim) call as well
    ;;  as declaring any variables that are used in the
    ;;  MP_StripPrefixRecEx function, like the 'position'
    ;;  variable.
    ;;  Generally speaking this is bad, bad coding practice as
    ;;  it requires one function to have intimate knowledge
    ;;  of the inner workings of another function, breaking
    ;;  black box rules and making for all kinds of potential
    ;;  maintenance woes. In this case I'm saying "it's ok"
    ;;  because this function is written entirely in the
    ;;  context of the other -- the two work together.
    (MP_StripPrefixRecEx string (ascii delim))
Having spent the time to optimize a little bit, the actual benefits may not be realized until the recurse levels get a little deep, as the following illuminates --
Using testString = "123" ...
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (TW_STRIPSTRING TESTSTRING "|")........1281 / 1.04 <fastest>
    (MP_STRIPPREFIXREC TESTSTRING "|").....1328 / 1.00 <slowest>
Using testString = "123|456" ...
    (MP_STRIPPREFIXREC TESTSTRING "|").....1469 / 1.02 <fastest>
    (TW_STRIPSTRING TESTSTRING "|")........1500 / 1.00 <slowest>
Using testString = "123|456|789" ...
    (MP_STRIPPREFIXREC TESTSTRING "|").....1562 / 1.02 <fastest>
    (TW_STRIPSTRING TESTSTRING "|")........1593 / 1.00 <slowest>
Using testString = "123|456|789|ABC" ...
    (MP_STRIPPREFIXREC TESTSTRING "|").....1562 / 1.06 <fastest>
    (TW_STRIPSTRING TESTSTRING "|")........1656 / 1.00 <slowest>
Using testString = "123|456|789|ABC|DEF" ...
    (MP_STRIPPREFIXREC TESTSTRING "|").....1593 / 1.12 <fastest>
    (TW_STRIPSTRING TESTSTRING "|")........1781 / 1.00 <slowest>
Using testString = "123|456|789|ABC|DEF|GHI|JKL|MNO|PQR" ...
    (MP_STRIPPREFIXREC TESTSTRING "|").....1781 / 1.18 <fastest>
    (TW_STRIPSTRING TESTSTRING "|")........2093 / 1.00 <slowest>
Sorry, that's all I've got for now.
« Last Edit: March 28, 2006, 06:38:29 PM by MP »
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
« Reply #17 on: March 28, 2006, 06:43:01 PM »
Thanks Michael.  Something (more) to study.
Slim©
  • The Dude Abides...
« Reply #18 on: March 28, 2006, 06:47:29 PM »
Normal around here...
Ron, did you get the help you needed?  :-)
I drink beer and I know things....
« Reply #19 on: March 28, 2006, 06:57:22 PM »
Oops, <big> sorry Ron.
« Reply #20 on: March 28, 2006, 07:38:41 PM »
I got all the help I needed and more....par usual. Thanks guys :)
« Reply #21 on: May 08, 2006, 05:23:10 PM »
Show off  :-D just kidding....you make it look so easy.
Just trying to get you to look at the problem / solution another way .. and have some fun at the same time .. honest.
If you find the lambda stuff annoying here's a lambdaless equivalent --
(defun StripXrefPrefix ( string / position )
    (if (setq position (vl-string-position 124 string 0 t))
        string
MP,
How could this be modified to strip the string down to thesecond to last bar -->>
ABC|123|456|789 to 456|789
Thanks,
Ron
« Reply #22 on: May 08, 2006, 05:46:03 PM »
Not sure I understand. Could you please show original data and desired data, for example --
Original: "ABC|123|456|789 to 456|789"
Desired: "789 to 456|789"
Thanks.
« Reply #23 on: May 08, 2006, 06:46:55 PM »
MP,
Does this help?
Original: "ABC|123|456|789"
Desired: "456|789
Original: "098|ABC|123|456|789"
Desired: "456|789
Instead of stripping out all of the "|" it leaves the last one and the text up to the second to last.
Thanks,
Ron
« Reply #24 on: May 08, 2006, 07:48:49 PM »
Edit: Simplified / renamed functions, re-ordered post to make comparison easier to discern.
Apologies -- written very quick, very dirty.
I don't really know what to call these functions but figured the candidates are better than foo1 and foo2.
Nonetheless, observe --
(defun KeepNthPlus ( n string delim / i code indexes )
    ;;  n used in same context as nth function
    ;;  delim is a one character string
    (setq i 0 code (ascii delim))
    (while (setq i (vl-string-position code string i))
        (setq indexes (cons (setq i (1+ i)) indexes))
        (   (null indexes) nil)
        (   (< n (length indexes))
            (substr string (1+ (nth n (reverse indexes))))
Versus --
(defun KeepReversedNthPlus ( n string delim / i code indexes )
    ;;  but counting from the end forwards
            (substr string (1+ (nth n indexes)))
        (   string   )
Set up some test data --
(setq testString "abc|def|ghi|jkl|mno")
Test KeepNthPlus --
(foreach i '(0 1 2 3 4)
    (princ
        (strcat
            "(KeepNthPlus "
            (itoa i)
            testString
            (vl-prin1-to-string
                (KeepNthPlus i testString "|")
            "\n"
Test KeepReversedNthPlus --
    (princ
        (strcat
            "(KeepReversedNthPlus "
            (itoa i)
            testString
            (vl-prin1-to-string
                (KeepReversedNthPlus i testString "|")
            "\n"
Test KeepNthPlus results --
(KeepNthPlus 0 "abc|def|ghi|jkl|mno" "|") => "def|ghi|jkl|mno"
(KeepNthPlus 1 "abc|def|ghi|jkl|mno" "|") => "ghi|jkl|mno"
(KeepNthPlus 2 "abc|def|ghi|jkl|mno" "|") => "jkl|mno"
(KeepNthPlus 3 "abc|def|ghi|jkl|mno" "|") => "mno"
(KeepNthPlus 4 "abc|def|ghi|jkl|mno" "|") => nil
Test KeepReversedNthPlus results --
(KeepReversedNthPlus 0 "abc|def|ghi|jkl|mno" "|") => "mno"
(KeepReversedNthPlus 1 "abc|def|ghi|jkl|mno" "|") => "jkl|mno"
(KeepReversedNthPlus 2 "abc|def|ghi|jkl|mno" "|") => "ghi|jkl|mno"
(KeepReversedNthPlus 3 "abc|def|ghi|jkl|mno" "|") => "def|ghi|jkl|mno"
(KeepReversedNthPlus 4 "abc|def|ghi|jkl|mno" "|") => "abc|def|ghi|jkl|mno"
Something to toy with, cheers.
« Last Edit: May 09, 2006, 08:06:15 AM by MP »
« Reply #25 on: May 09, 2006, 09:14:03 AM »
MP,
Your knowledge of writing code never ceases to amaze me. Whether it be simple or complicated you always find an elegant way to solve a problem :). This is exactly what I was looking for.
Thanks again,
Ron
« Reply #26 on: May 09, 2006, 12:27:14 PM »
Awefully nice of you to say Ron, that is the illusion I'm shooting for -- Thanks!
 :lol:
« Reply #27 on: May 09, 2006, 02:38:33 PM »
 :lol:
