Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Amsterdamned on October 19, 2021, 05:32:43 AM
Title: I have a different value in entget results than with the "list" command in acad
Post by: Amsterdamned on October 19, 2021, 05:32:43 AM
Hello,
my last post got me nowhere, so i try to explain differently.
I have some export out of revit where in need to create some data from I cannot do in revit, complicated to explain.
It is for prefab fire sprinkler systems, I need to create a xlm based file with instructions for my customers own system should be straight forward I thought but I run into some basic problems.
But I run into a snag, some blocks are showing wrong  dxf 10 result for the insertion point, whenever dxf 210 is not (0.0 0.0 1.0)
Some are with 210 (0.0 0.0 -1.0) the it is maybe to solve with a 3d mirror but sprinkler systems also can run with a slope, then it is more complicated.
But the property dialog box in acad and the list command show the right results.
with entget:
Select object: ((-1 . <Entity name: 7ff6af226cf0>) (0 . "INSERT") (330 .
<Entity name: 7ff6af291f00>) (5 . "27AF") (100 . "AcDbEntity") (67 . 0) (410 .
"Model") (8 . "P-PIPE") (62 . 150) (100 . "AcDbBlockReference") (2 .
"NLRS_65_PIF_UN_Lassok_gen - Lassok_draad-17552420-_3D - bernd_bauer_") (10
2159.88 88008.3 -3350.0) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0)
(71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 -1.0))
with list
           BLOCK REFERENCE  Layer: "P-PIPE"
                            Space: Model space
                   Color: 150    Linetype: "BYLAYER"
                   Handle = 27af
       Block Name: "NLRS_65_PIF_UN_Lassok_gen - Lassok_draad-17552420-_3D -
bernd_bauer_"
                at point, X=-2159.8771  Y=88008.3131  Z=3350.0000
   X scale factor:    1.0000
   Y scale factor:    1.0000
   Z scale factor:    1.0000
Extrusion direction relative to UCS:
                   X=   0.0000  Y=   0.0000  Z=  -1.0000
  Scale uniformly: No
  Allow exploding: Yes
how is this possible? where does acad get the right information from isf not the entget function?
So my question is, how can I retrieve those “correct” results?
Title: Re: I have a different value in entget results than with the "list" command in acad
Post by: mhupp on October 19, 2021, 08:09:13 AM
Well if you would have respond to the other posts. I would have suggest using the trans function then.
https://documentation.help/AutoCAD-ALISP-VLISP/WS73099cc142f4875516d84be10ebc87a53f-79d0.htm
Post by: Amsterdamned on October 19, 2021, 11:45:45 AM
the 3d mirror does not work . its not a polyline but an insert. i tried the trans function as well, but does not change a thing.
Post by: roy_043 on October 19, 2021, 12:11:34 PM
(trans '(2159.88 88008.3 -3350.0)  '(0.0 0.0 -1.0) 0) => (-2159.88 88008.3 3350.0)
Post by: mhupp on October 19, 2021, 02:06:26 PM
I get that the 3d mirror didn't work. kinda glanced over inserts thinking you meant insert point and not blocks. (my bad)
This should get you to where you need to be.
(defun C:trans (/ ss en pt)
  (if (setq ss (ssget))
    (foreach en (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (if (equal '(210 0.0 0.0 -1.0) (assoc 210 (entget en)))
        (setq pt (trans (cdr (assoc 10 (entget en))) '(0.0 0.0 -1.0) 0))
        (setq pt (cdr (assoc 10 (entget en))))
Post by: Amsterdamned on October 19, 2021, 04:35:55 PM
thanks! i never used trans other than with the 0 and 1 freature! that works!
