Code Red => AutoLISP (Vanilla / Visual) => Topic started by: domenicomaria on May 24, 2021, 03:12:29 AM
Title: catch the objects of an exploded group
Post by: domenicomaria on May 24, 2021, 03:12:29 AM
I need to catch all the objects that were member of an exploded group . . .
Does somebody know a simple way to get this ?
(defun C:K ( / ent-lst x-el x-en)
   (setq x-el (LM:entlast (entlast) ) )
   (setq x-en (entsel "\nselect GROUP to EXPLODE :") )
   (vl-cmdf "ungroup" x-en)
   (setq ent-lst (LM:entnexttoend x-el) )
(setq ent-lst (LM:entnexttoend x-el) ) does not work !
Title: Re: catch the objects of an exploded group
Post by: Lee Mac on May 24, 2021, 04:01:14 AM
Ungrouping is not the same action as exploding - it does not add new entities to the drawing database; you should instead examine the members of the group prior to ungrouping.
Post by: domenicomaria on May 24, 2021, 04:28:02 AM
I supposed that . . .
Post by: domenicomaria on May 24, 2021, 07:49:20 AM
"simple" means not elegant, but working !  :whistling:
Post by: tombu on May 24, 2021, 10:25:38 AM
Why not as Lee sugusted use code like
(setq ss(ssget))
to select the group which puts all the group entities into a selection set?
Maybe if you posted what code you're working on someone here would offer a simple elegant solution.
Post by: domenicomaria on May 24, 2021, 11:08:13 AM
  1. (defun :GROUP-GET-DATA (e / l r )
  2.    (if
  3.       (and
  4.          (setq l (entget e ) )
  5.          (setq r (assoc 330 l) )
  6.          (setq r (entget (cdr r) ) )
  7.          (= (cdr (assoc 0 r ) ) "GROUP")
  8.       )
  9.       r
  10.    )
  11. )
  12.
  13.
  14. (defun :M-ASSOC (code l)
  15.    (mapcar
  16.       (function cdr)
  17.       (vl-remove-if-not
  18.          (function (lambda (i / code)   (= (car i) code) ) )
  19.          l
  20.       )
  21.    )
  22. )
  23.
  24. (defun c:XG ( / grp-data grp-ss x-en )
  25.    (and
  26.       (setq x-en (entsel "\nselect GROUP to EXPLODE :") )
  27.       (setq grp-data (:GROUP-GET-DATA (car x-en) ) )
  28.       (setq grp-ss (ssadd) )
  29.       (foreach en (:M-ASSOC 340 grp-data)  (setq grp-ss (ssadd en grp-ss) ) )
  30.       (vl-cmdf "ungroup" (car x-en) )
  31.       (vl-cmdf "select" grp-ss "")
  32.    )
  33.    grp-ss
  34. )
  35.
it seems to work . . .
Post by: Marc'Antonio Alessi on May 24, 2021, 01:21:21 PM
Only an example from tombu suggestion:
(defun C:XG2 ( / SelSet)
   (princ "\nSelect GROUP to EXPLODE: ")
   (and
     (setq SelSet (ssget))
     (vl-cmdf "_.UNGROUP" (ssname SelSet 0))
     (vl-cmdf "_.SELECT" SelSet "")
Post by: domenicomaria on May 24, 2021, 02:31:50 PM
   (and
8-)
e si ...
Post by: ronjonp on May 24, 2021, 04:27:56 PM
Maybe this too:
  1. (defun c:foo (/ d e s)
  2.   (if (and (setq e (car (entsel)))
  3.            (setq d (cdr (assoc 330 (entget e))))
  4.            (= "GROUP" (cdr (assoc 0 (entget d))))
  5.       )
  6.     (progn (setq s (ssadd))
  7.            (foreach x (entget d) (and (= 340 (car x)) (setq s (ssadd (cdr x) s))))
  8.            (sssetfirst nil s)
  9.            (entdel d)
  10.     )
  11.   )
  12.   (princ)
  13. )
*localized 's'
Post by: domenicomaria on May 25, 2021, 03:11:05 AM
Maybe this too:
  1. (defun c:foo (/ d e)
  5.       )
  9.            (entdel d)
  10.     )
  11.   )
  12.   (princ)
  13. )
very nice and interesting !
Post by: domenicomaria on May 26, 2021, 10:24:51 AM
ronjonp thank you.
Maybe for somebody it is obvious, but . . .
this means that
(entdel d)
deletes the group definition
but doesn't delete the entities contained in the group !
In other words, it explodes the group.
Right ?
Post by: ronjonp on May 26, 2021, 11:20:48 PM
ronjonp thank you.
this means that
(entdel d)
Right ?
Yes  :-) .. well it deletes the group the entities are contained in.
