CAD Forums => CAD General => Topic started by: alanjt on January 05, 2018, 09:14:15 AM
Title: Software to batch convert DGN files to DWG
Post by: alanjt on January 05, 2018, 09:14:15 AM
Does anyone have any recommendations on a program that will convert an entire directory of DGN files (microstation project) to DWG?
I know Civil 3D has the DGNIMPORT and DGNINSERT commands, but I don't want to have to do that for 30 files.
Any thoughts would be greatly appreciated.
Title: Re: Software to batch convert DGN files to DWG
Post by: ronjonp on January 05, 2018, 09:18:25 AM
Probably not affordable but the fastest batch convert I've seen is using Microstation. If you want, send the files to me and I can convert them for you.
Post by: ronjonp on January 05, 2018, 09:33:38 AM
Alternatively, you could script it using vl-directory-files and -DGNIMPORT :)
Post by: VVeli on August 04, 2021, 02:55:33 AM
Just update this topic. There was one solution in Autodesk forum. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/dgn-to-dwg-lisp-program-not-working/td-p/9188123 (https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/dgn-to-dwg-lisp-program-not-working/td-p/9188123)
-VV
