CAD Forums => CAD General => Dynamic Blocks => Topic started by: Willie on March 15, 2016, 07:47:27 AM
Title: Dynamic Title Block Revision Box
Post by: Willie on March 15, 2016, 07:47:27 AM
I thought I must share.
I have been thinking of  incorporating multiline attributes in a revision block, where the size of the frame around the text can easily be adjusted and that the attributes would stay in the center.
I came up with the attached, but the help came from this: http://www.cad-notes.com/how-to-keep-attributes-at-dynamic-block-center/ (http://www.cad-notes.com/how-to-keep-attributes-at-dynamic-block-center/).
Title: Re: Dynamic Title Block Revision Box
Post by: lamarn on March 15, 2016, 09:54:53 AM
Willie, that is a really nice piece of dynamic block work!
Thanks for sharing. I have nothing more to add... i'm just going to use it :)
Post by: ChrisCarlson on March 16, 2016, 01:21:38 PM
Would time have been better spent simply using an AutoCAD table? The only difference is that you are editing the cell contents within the properties window vs within the individual cells.
Post by: mjfarrell on March 16, 2016, 01:59:08 PM
or a sheet set table....
Post by: Willie on March 16, 2016, 02:21:46 PM
Maybe yes, but it's part of a title block.
