Code Red => .NET => Topic started by: Kerry on November 30, 2007, 12:18:01 AM
Title: (GetEnv equivalent in C#
Post by: Kerry on November 30, 2007, 12:18:01 AM
Question :
I'm trying to retrieve the Acad Search Path variable value
equivalent to (GetEnv "ACAD") in Lisp
As far as I can determine this can't be done with the NET API Library
Anyone have any ideas about a (GetEnv ... and (SetEnv ... equivalent in C# ?
Something similar to one of these :-
Title: Re: (GetEnv equivalent in C#
Post by: T.Willey on November 30, 2007, 03:10:05 AM
I don't see a way with reflector, or in the Arx docs, as the way you would do it in lisp, it doesn't look like you can with C#.  Lisp would be
(vla-get-SupportPath
  (vla-get-Files
    (vla-get-Preferences
      (vlax-get-Acad-Object)
You can get an object, from the Application object, for the Preferences, but I don't know what you can get from there.
Post by: Kerry on November 30, 2007, 03:24:29 AM
Thanks Tim, that was my conclusion too.
there is AN AcedGetEnv(.. in arx that may perhaps could be PEnvoke'd ... but I'm lost there ..
.. or at a pinch, perhaps the ActiveX methods used in VLisp and vba could be addressed via COM.
My brains not working at the moment, so I'll come back to it.
Post by: FengK on November 30, 2007, 04:06:12 AM
I'm guessing here. Would info in this post be helpful?
http://www.theswamp.org/index.php?topic=10017.msg135522#msg135522
Can you access "Vl.Application.16" via C#?
Post by: Kerry on November 30, 2007, 04:47:14 AM
This is trying with Autodesk.AutoCAD.Interop referenced
I'm out of my depth here ... [gurgle, gurgle, gurgle ]
the piccy to prove it :
Post by: Kerry on November 30, 2007, 05:17:10 AM
like a dog at a bone ....
Post by: Glenn R on November 30, 2007, 07:05:55 AM
Kerry,
I was going to post up how to do the COM thing once I returned from walking the mutt, but I see you've already done it.
Here (http://www.theswamp.org/lilly_pond/GlennR/acedGetEnv.html) is an implementation of a wrapper for acedGetEnv.
If you look at the docs, it tells you that acedgetenv will look in a particular registry key for the value or failing that, the windows sys env table. You could use the built-in acad .net functions to find the product root key and then do a reg search thru .net, then the system environment variables if you wanted to implement your own.
Cheers,
Glenn.
Post by: Kerry on November 30, 2007, 08:06:16 AM
Thanks Glenn.
That's the direction I wanted to head in next.
I noticed you called that 'setenvwrapper' ..
do you actually have a setenvwrapper using acedGetEnv acedSetEnv ?   <<<< EDIT
Post by: Glenn R on November 30, 2007, 08:17:56 AM
Sorry Kerry, that was a slip of the fingers on this UK keyboard  :-) It was supposed to be getenv...
Post by: Kerry on November 30, 2007, 08:26:20 AM
I've heard the spelling over there is weird too !
:-D
ps: I really meant using acedSetEnv
Post by: Glenn R on November 30, 2007, 08:32:07 AM
Here (http://www.theswamp.org/lilly_pond/GlennR/acedGetSetEnvWrappers.html) is an updated code file with both acedGetEnv and acedSetEnv.
Is that what you're after?
Cheers,
Glenn.
Post by: Chuck Gabriel on November 30, 2007, 08:34:45 AM
Is this a permanent relocation, or are you just visiting?
Post by: Glenn R on November 30, 2007, 08:38:21 AM
Hey Chuck,
Permanent, or at least until we decide to go someplace else  :-)
Shipped the dog and the cat as well. Max (the beagle), seems to be loving it - all the new smells and cooler weather. The cat doesn't seem to care one way or the other as long as there's food and a heater to sleep by.
Cheers,
Glenn.
Post by: Kerry on November 30, 2007, 08:49:08 AM
Cheers,
Glenn.
perfectamundo !
I hope Jane was happy to see the animules.
 .. I bet Surrey is a little greener than the landscape you left here.
Post by: Bryco on November 30, 2007, 08:50:19 AM
Well done Kerry and Glenn.
Autodesk.AutoCAD.Interop wasn't in my cad but I did find it in Objectarx 2008\inc
Post by: Glenn R on November 30, 2007, 08:52:45 AM
Yes, she was, but it didn't take her long to remember what a pain the mutt can be.
Yeah, it's green here and blasted brown if not bare earth there.
Cheers,
Glenn.
Post by: Glenn R on November 30, 2007, 08:54:42 AM
It should be on the COM tab in the add reference dialog Bryce. Kerry should be able to post a nice piccy of the entries you need to reference seeing as he's snagit happy at the moment ;)
Post by: Kerry on November 30, 2007, 10:17:18 AM
OK
just Reference the  AutoCAD 2008 Type Library
and add the using statement
using Autodesk.AutoCAD.Interop;
added:
just realised, these threads must look weird if the viewer isn't logged in ( a member) ... cause the piccys really do tell a story :-)
Post by: Bryco on November 30, 2007, 01:29:07 PM
Thanks mate. Picture is worth a 1000 beers.
Post by: Glenn R on November 30, 2007, 02:22:32 PM
And Kerry is the king of piccies  :-D
Post by: Kerry on November 30, 2007, 07:04:09 PM
[you] can be as well !
http://www.theswamp.org/index.php?topic=20184.msg245455#msg245455
I'm just too lazy to write properly .. succinct is difficult.
[you] of course being [you the reader].
Post by: Glenn R on November 30, 2007, 07:10:09 PM
Duly noted my friend.
Cheers,
Glenn.
Post by: Chumplybum on December 02, 2007, 07:10:29 PM
what about:  Autodesk.AutoCAD.ApplicationServices.UserConfigurationManager ????
Post by: Kerry on December 02, 2007, 11:55:42 PM
Haven't tried that Chumplybum .. have you ?
Post by: It's Alive! on December 03, 2007, 12:33:03 AM
sorry, I was board  :laugh:
AcMgdWrprs.Utilities.GetEnv("ACAD")
for 2007
Post by: Chumplybum on December 03, 2007, 01:11:07 AM
this is the same as (getenv "ACAD")...
Dim UserConfigurationManager As Autodesk.AutoCAD.ApplicationServices.UserConfigurationManager = Autodesk.AutoCAD.ApplicationServices.Application.UserConfigurationManager
Dim ProfileBase As Autodesk.AutoCAD.ApplicationServices.IConfigurationSection = UserConfigurationManager.OpenCurrentProfile
Dim GeneralRegKey As Autodesk.AutoCAD.ApplicationServices.IConfigurationSection = ProfileBase.OpenSubsection("General")
System.Windows.Forms.MessageBox.Show(GeneralRegKey.ReadProperty("ACAD", "").ToString)
Post by: Kerry on December 03, 2007, 02:03:49 AM
cool !
I'll have a play tonight ... Thanks.
Post by: Kerry on December 03, 2007, 02:32:32 AM
Yes,Mark, that seems fine.
I made a method that's a little more generic
Haven't tested for invalid data in this version ...
        public static object GetProfileEntry(string sSubSection, string sProperty)
            UserConfigurationManager ucManager = Application.UserConfigurationManager;
            IConfigurationSection currentProfile = ucManager.OpenCurrentProfile();
            IConfigurationSection subSection = currentProfile.OpenSubsection(sSubSection);
            return subSection.ReadProperty(sProperty, "");
A piccy for Joe ..
Post by: Kerry on December 03, 2007, 06:13:02 AM
I s'pose there's really no need for a method when we can do it in-line without intermediate variable assignments ..
 string sSupportPath = AcadApp.UserConfigurationManager.OpenCurrentProfile().
                                 OpenSubsection("General").ReadProperty("ACAD", "").ToString();
Post by: Glenn R on December 03, 2007, 06:52:51 AM
                                 OpenSubsection("General").ReadProperty("ACAD", "").ToString();code]
True, but the function looks better; is easier to read and if one property in that 'property chain' fails, it's a lot harder to debug...just some thoughts.
Cheers,
Glenn.
Post by: Kerry on October 17, 2009, 02:43:21 AM
I've coded this as an exercise in answer to a question elsewhere.
The p/Envoke for GetEnv and SetEnv seemed the easiest way to handle the Variables stored in the  Fixed Profile ->General section of the registry.
.. Other Variables are stored in Profiles->  <<UserProfile>>  -> General
any tips for improvement appreciated.
// (C) CodeHimBelonga kdub @TheSwamp 20091017
using System;
using System.Text;
using System.Runtime.CompilerServices;
using System.Runtime.InteropServices;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(KDUB_testing.MyTestCommands))]
namespace KDUB_testing
    public class MyTestCommands
        // p/Envoke from Acad.exe
        [System.Security.SuppressUnmanagedCodeSecurity]
        [DllImport("acad.exe",
            CharSet = CharSet.Auto,
            CallingConvention = CallingConvention.Cdecl)]
        private static extern int acedGetEnv(string envName, StringBuilder ReturnValue);
        private static extern int acedSetEnv(string envName, StringBuilder NewValue);
        [CommandMethod("DoIt", CommandFlags.Modal)]
        public void MyGetEnv()
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            string mainCuiFile = AcadApp.GetSystemVariable("MENUNAME") as string;
            ed.WriteMessage("\nMenuName : {0}", mainCuiFile);
            const int maxResultLength = 1024;
            StringBuilder sbRes = new StringBuilder(maxResultLength);
            acedGetEnv("ACAD", sbRes);
            ed.WriteMessage("\nValue of ACAD environment variable: {0}", sbRes.ToString());
            acedGetEnv("AcetMoveBak", sbRes);
            ed.WriteMessage("\n\nMoveBak Variable: {0}", sbRes.ToString());
            // assume the folder exists for this exercise
            StringBuilder sbResNew = new StringBuilder("c:\\DWG-BAK\\Auto");
            acedSetEnv("AcetMoveBak", sbResNew);
            ed.WriteMessage("\n\nMoveBak Variable is Now : {0}", sbRes.ToString());
Post by: It's Alive! on October 17, 2009, 11:17:56 AM
perfect!
Post by: Kerry on October 18, 2009, 10:01:01 PM
except as Tony T pointed out ... we don't need a StringBuilder for the acedSetEnv ... a String is sufficient.
[ long distance critique appreciated :) ]
Post by: It's Alive! on October 19, 2009, 01:30:23 AM
True, I thought of that too , but then again depends on the usage, example;
if I wanted to append search paths to the environment "ACAD" then Stringbuilder might be more efficient.
Post by: It's Alive! on October 19, 2009, 01:43:21 AM
you could always make it overloaded  :-)
namespace ExecMethod
 public static class Commands
  [DllImport("acad.exe", CharSet = CharSet.Auto,
  internal static extern int acedGetEnv(string envName, StringBuilder ReturnValue);
  internal static extern int acedGetEnv(string envName, string ReturnValue);
  [DllImport("acad.exe",CharSet = CharSet.Auto,
  internal static extern int acedSetEnv(string envName, StringBuilder NewValue);
  internal static extern int acedSetEnv(string envName, string NewValue);
  [CommandMethod("doit")]
  static public void doit()
   try
    AcEd.Editor editor =
     AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
    string env = new string(char.MinValue, 1024);
    acedGetEnv("ACAD", env);
    acedSetEnv("ACAD", env);
    editor.WriteMessage("{0}", env);
   catch (System.Exception ex)
      MdiActiveDocument.Editor.WriteMessage
       ("\n{0}\n{1}", ex.Message, ex.StackTrace);
Post by: Kerry on October 19, 2009, 04:55:21 AM
You're a sick puppy Fronkensteen  :wink:
