CAD Forums => CAD General => CAD Standards => Topic started by: yyou on July 14, 2004, 06:09:46 PM
Title: Blip mode on/off
Post by: yyou on July 14, 2004, 06:09:46 PM
I usually have my blip mode on.  It does not bother me.  On or off I don't even notice.  I only notice when I need them to be on and they are not.  When do I need them?   When I need to modify a bunch of similar entities, it helps me to see which one I already did.
Post by: Keith™ on July 14, 2004, 08:52:45 PM
Blipmode is ok, but I sometimes find myself trying to erase those confounded tics only to realize they are blips, not linesor points in the drawing
Post by: Craig on July 14, 2004, 08:54:20 PM
Blipmode off for me all the time. They are more of an annoyance for me
Post by: Slim© on July 14, 2004, 08:57:11 PM
Always off
Post by: Dent Cermak on July 14, 2004, 10:55:55 PM
I HATE BLIPMODE!! Why didn't they get rid of that rather than all the stuff I use everyday!! ALL the good stuff from 14 didn't make it to LDD3. Thank goodness for the retired list!!
Post by: daron on July 15, 2004, 08:30:32 AM
I agree. They should've done away with blipmode, but instead they semi-remove tracking and replace it with temp tracking. It's not the same. Tracking was so cool. You could set objects on a point, then move that point and keep moving it until you got what you were looking for. It seems odd to need that, but there was a time where I did need it, then they went and hid it away. It probably doesn't even exist anymore.
Post by: Keith™ on July 15, 2004, 12:25:49 PM
I never used traking... it was always getting in the way of my snap settings.....
Back on track....
I no longer use blipmode
Post by: M-dub on July 15, 2004, 12:35:37 PM
Quote from: Dent Cermak
Cheers, Dent!  What's the friggin' point?
I actually created a button in our menu just to shut them off...Guess which one...
(http://theswamp.org/lilly.pond/M-dub/MiscBar.PNG)
Post by: JohnK on July 15, 2004, 12:46:59 PM
Why dont you update that button with this:
(setvar "blipmode" (boole 6 (getvar "blipmode") 1))
Post by: CADaver on July 15, 2004, 12:53:38 PM
Quote from: Daron
As indicated by the first post in this thread, some folks still use it.
Prior to fast regens, toggling blipmode on and off was a totally transparent "REDRAW", but I haven't used it since.
Post by: yyou on July 15, 2004, 12:59:27 PM
:shock:  Wow, overwhelming.  Autodesk should look at this topic.
Post by: M-dub on July 15, 2004, 01:09:39 PM
Quote from: Se7en
Thanks, but I'd only use that if I wanted them to turn blipmode back on.  I only want them to turn it off...
(I know I'm letting my personal opinion interfere with the operation of everyone, but I hate blips!!!!!
Post by: M-dub on July 15, 2004, 01:10:08 PM
Quote from: yyou
Likely wouldn't make any difference whatsoever... :roll:
Post by: JohnK on July 15, 2004, 01:18:29 PM
Heh, did you run it?
Post by: t-bear on July 15, 2004, 01:25:14 PM
Actually, it's interesting to see that someone found a use for a function that everyone else HATES.... Just shows to go that there are a million ways to do anything in CAD.....COOL, eh?
Post by: M-dub on July 15, 2004, 01:34:05 PM
Quote from: Se7en
Yup...It just toggles BM, right?  or am I way off?
Post by: JohnK on July 15, 2004, 01:39:16 PM
yes. Now why wouldnt that be better? If you give you menu out to others woulnt you want the give them the option to decide WHEN to use the button and not how CAN they use the button?
Post by: M-dub on July 15, 2004, 01:42:05 PM
I hear ya, but to be completely honest, it is extremenly rare to find a drawing with blipmode on.  I just made that button more to amuse myself...;)
That is a good idea though...I'll keep it in mind for other commands in the future...
Post by: yyou on July 15, 2004, 02:12:31 PM
Actually those situations only occur once in a while.  Mostly are in atrrib or text cases.  One time I recall, the atrrib txt in room-name blks which came from the client were at 6" high.  Our standard is 4.5.  I tried to used attredef to fix it but all room number turn to 104 on every block.  So I have to go to each block and scale it down.
On the screen, I cannot tell the diff between 6" blk and 4.5" blk. That was when blipmode came in handy.  Now with the tick mark, I can see the blocks that had been scaled down so I did not pick them again.
Post by: TR on July 15, 2004, 06:15:14 PM
The blipmode variable is stored in the registry, not the drawing.
Post by: JohnK on July 15, 2004, 06:57:08 PM
heh. You sure 'bout that Tim?!
Post by: TR on July 15, 2004, 08:59:56 PM
Positive. My boss uses blipmodes and I do not. We often work on the same drawing and I've yet to see blips while working.
Also the system variable browser thing that comes in express tool for 2000i says it's stored in the registry.
Post by: Keith™ on July 15, 2004, 11:11:50 PM
blipmode is indeed stored in the registry...
Quote from: Windows Registry
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R16.0\ACAD-201:409\Profiles\<<Unnamed Profile>>\General\Blipmode
Post by: Jassper on July 16, 2004, 12:57:44 AM
Quote from: t-bear
Only a Million???????????  :)  :)
Blipmode - so obnoxious!
Post by: t-bear on July 16, 2004, 08:04:44 AM
Yah, but so am I and you let me hang around ..... on rare occasions I'm even useful! (can't think of ant examples at the moment, but......)
(Oh yah, correcting Seben's speling)
Post by: Slim© on July 16, 2004, 08:26:44 AM
Quote from: t-bear
I see you caught Mark's cold.  :D
Post by: SMadsen on July 16, 2004, 08:32:02 AM
BLIPMODE rules!
Post by: M-dub on July 16, 2004, 08:34:35 AM
Quote from: SMadsen
BLIPMODE rules!
Bite your tongue! :twisted:
