CAD Forums => Vertically Challenged => Land Lubber / Geographically Positioned => Topic started by: Dinosaur on October 19, 2006, 10:46:44 PM
Title: Civil 3D - Mini Tutorials On Line
Post by: Dinosaur on October 19, 2006, 10:46:44 PM
Member Michael Farrell has posted the first in a series of mini lessons for Civil 3D.  The first AVI addresses the basics of navigating through the unique Toolspace interface lasts around 20 minutes.  It can be downloaded at:
http://primeservicesglobal.com/tutorials.php
fixed link in post MST
appears the link broke again ... should work again
Title: Re: Civil 3D - Mini Tutorials On Line
Post by: Dinosaur on October 26, 2006, 09:36:44 PM
A second presentation is now available that covers tiips for setting up a template and migration from Land Desktop
Post by: Mark on October 26, 2006, 10:21:30 PM
Coming Soon POINTS!
Can't wait for that one. Thanks Mr. Farrell. :-)
thanks for the links Steve, I'll download it in the morning.
Post by: dgreble on October 27, 2006, 09:35:17 AM
Thanks for the heads up Dino! :-D
Post by: Dinosaur on August 08, 2007, 12:34:48 PM
BIG OL' BUMP
Michael has added a new tutorial to his list and has made significant improvement in the audio quality.  This new file is a 30 minute presentation on creating an existing surface with Civil 3D
Post by: mjfarrell on August 13, 2007, 01:44:03 PM
DinØ,
Look a little closer and you will see a session covering the basics of MAP Drawing Cleanup operation as well.
Post by: jonesy on August 17, 2007, 04:35:12 AM
Bookmarked for the MAP cleanup. I'll look at that when I get back to work on Monday
Thanks Michael
Post by: dfarris75 on August 28, 2007, 03:31:46 PM
Just got around to downloading the surface tutorial. The sound is indeed much improved, but the narration seems to be about 10-15 secs ahead of the video. :lol:
The file size is tremendously large as well. I wonder if there's a way to whittle that down any...
I also just noticed that the link for the Map Cleanup tutorial is pointing to the Migration video. You might want to smack around your webmaster a little.
Post by: mjfarrell on May 15, 2008, 12:43:17 PM
Well, file sizes are still a little large, however the audio seems be more synced up. Still trying to figure out where that delay came from? I didn't think it took that long for sound to go through the DA converter.
And a hearty thanks to Darcy for the shiny new wrapper!
Post by: dfarris75 on May 27, 2008, 12:56:37 PM
Hey no problem. You are more than welcome. I notice the xhtml code isn't checking out now. Did you change something? We might have to look at fixing that or just removing the code checkers.
Post by: mjfarrell on May 27, 2008, 12:59:06 PM
I edited the data to add new links? Perhaps you might review the source code and advise, as to if it was ME or the Page Breeze editor responsible?
Post by: mjfarrell on June 06, 2008, 10:25:58 AM
 :roll:
so did I break it?
Post by: dfarris75 on June 06, 2008, 11:03:56 AM
If you click the xhtml button it will "qc" the page and tell you what's wrong. :wink:
Post by: mjfarrell on June 06, 2008, 11:08:09 AM
And then...I will know how to fix it too, right? :lol:
Post by: dfarris75 on June 06, 2008, 11:45:54 AM
I would think that an intellectual such as yourself would be able to yes. :whistle:
Title: Re: Civil 3D - Expression in Point Label
Post by: mjfarrell on November 27, 2011, 11:46:18 PM
A tutorial that introduces a basic EXPRESSION in a point lable.
The user wanted to show elevations in MM which is a non-standard format for Civil 3D to display the values in.
Expression in Point Label (http://primeservicesglobal.com/tutorials/expressions.mp4)
Title: Re: Civil 3D - Complex Assembly from Simple Parts
Post by: mjfarrell on January 26, 2012, 04:58:57 PM
A tutorial that produces a pretty complex Assembly.
The tools that are used are the basic Generic Links, the end result is a fairly complex Assembly
without use of the Sub-Assembly composer.  I chose this route as not all have access to that other tool.
Take a look at what you can do with a Couple of Generic Pavement Sections, some Link Widths and Slopes,
and some Marked Points!
Powerfull Generic Links (http://primeservicesglobal.com/tutorials/genericlinks.mp4)
Post by: mjfarrell on February 07, 2012, 08:30:11 PM
A tutorial that shows two ways to create a Cut/fill benched embankment.
One solution is fairly simple.
The other puts a Conditional assembly to good use. And I try to explain that the conditional assemblies are
used much like a(n) IF>>THEN statement in programing, and that their layout parameters are just for graphical purposes.
http://www.primeservicesglobal.com/tutorials/Conditions.mp4 (http://www.primeservicesglobal.com/tutorials/Conditions.mp4)
Post by: sinc on February 07, 2012, 10:25:43 PM
useed much like a(n) IF>>THEN statement in programing, and that their layout parameters are just for graphical purposes.
I would LOVE it if we could apply some sort of visual style to our Assemblies, so that they look like a "Typcial Section" in a plan set.  Then we could just put our Assembly in a paperspace viewport, and have a "Typical Section".  But because we get this funky "layout parameters for graphical purposes" garbage (and because the distances are not auto-dimensioned in a plan-readable fashion), that isn't possible.  Too bad.  Maybe something for the "wish list", for any Autodesk lurkers out there.
Post by: mjfarrell on February 08, 2012, 08:31:42 AM
One can get close to what you are after using Code Sets on a Section View....
Although I know absolutely that isn't the same as what you are after.
And in order of Importance...I'd like to see integrated Hydrology tools, and MAP functionality with C3D objects far ahead of this.
Post by: sinc on February 08, 2012, 06:31:17 PM
Unfortunately, doesn't seem to be on Autodesk's radar.  And I know when I've mentioned this in personal communications with people like Peter Funk, I get stony silence as a response.  If anything, they seem to be working toward making C3D and Map LESS compatible with each other.
Post by: mjfarrell on February 08, 2012, 06:35:40 PM
ID10TS
I guess it's more important to ready the REVIT version of whatever Civil product to be named later that they will force on us, just as Civil 3D actually becomes both Stable and Usable.
A$$H@TS
Post by: sinc on February 08, 2012, 10:23:07 PM
I've seen posts on places like LinkedIn where people seem to think that Revit Civil will be replacing Civil 3D.  But that's probably idiocy on the part of people who are posting to LinkedIn.
Post by: sinc on February 08, 2012, 10:29:51 PM
Well anyway... to get back to the "Mini-Tutorial" theme of this thread...
This video on F2F in C3D has been getting a huge number of hits ever since I posted it...  Seems to have struck a nerve.  :)
So here's a link to it:
http://www.quuxsoft.com/videos/ProcessingSurveyData.aspx
Post by: Leafrider on May 24, 2012, 04:02:35 PM
Revit Civil is a pipe dream for Revit users. Revit clearly lacks Civil 3D tools and functionality. The day it replaces Civil 3D is many many moons away. People shouldn't take that comment as anything but an opinion. Great video thanks for sharing.
Post by: DaveD on May 08, 2013, 02:26:48 PM
sinc. Awesome.  Thanks for the informative survey vid. It's something I haven't had much opportunity to use, but am now needing.
Post by: spudule on May 14, 2014, 07:47:33 AM
I was asked to singlehandedly design Civil for Revit, or rather bump it's functionality. I did some hunting round the wishlists and I found THIS. Which I now liberally chuck at people to shut them up.  :pissed:
(https://drive.google.com/file/d/0B1Hhg32lG6xpZzFOZ1FQTUpTelE/edit)
