CAD Forums => CAD General => Topic started by: VerticalMojo on January 16, 2004, 04:37:39 PM
Hey guys, Ive been looking for this
(http://theswamp.org/lilly.pond/VerticalMojo/SYMBOL%20Y.jpg)
in my character map and I dont think its there...... does anybody know where I could get it?
Maybe what I wanted to say was....... is there any way I can edit my character map? Make my own? The picture above is a 3 phase, grounded neutral...... I wanted to be able to put that in my attribute.......
Nivuahc I know you know this stuff........
Ha Ha I thought I recognised parts of it I was looking through my blocks thinking I'm sure Ive seen something similar to that before!
Nevermind guys found the private character editor........ 8)
Share? :-)
You can also create a shape using Expresstools
Share? :-)
Think he's looking at the Microsoft one:
http://www.microsoft.com/windows2000/en/server/help/default.asp?url=/windows2000/en/server/help/app_start_character_editor.htm
I had a problem before trying to make a left curly bracket { (can be found in mtext-symbol-other-GDT).The symbol was the one I wanted but when inserted it appeared to be bolder than the rest,didnt have bold on either.Also thsat symbol is used to enclose other text so it needed to be stretched like a block but it just looked naff when stretched.Let us know what you think of that character editor Mojo.
(for windows) To open Private Character Editor, click Start, click Run, and then type eudcedit.
Now I have come to another problem....... When I create my character and link it to lets say RomanS then it should
appear in the Fonts under RomanS. But I cant get it to work.
Also, when am in mtext and retrieve the custom character from the character map (its under all fonts (private
characters)) and paste it in the character will appear normal....but when I press ok it will appear as a question mark (?).
Some one open a window..... Its getting hot in here. :?
IHM........
(I hate Mondays) :evil:
BTW, I will have to send a text file if somebody from another computer wanted to read it huh? Is there a way to keep it in the dwg itself?
Well guess I will bring this up again.....
Is there a way to add a character in DTEXT? I know that if I put %%nnn (nnn indicating the character code) but the code that I want to put in there is 0x44, I think (if you open character map>symbols>0x44)......Or its under SYMBOLS font. SHIFT + D will get the symbol I need in MTEXT but I dont know how to get it on DTEXT.... :?
Reason for this is I need to put it in a Attribute.....
Any Ideas?
