Code Red => .NET => Topic started by: sigster on February 06, 2024, 05:32:22 AM
Hi
Can someone help with this Please
I am try to read Polyline from Shapefile and write to DWG using DotSpatial and ACadSharp
I can read and write the DWG but I get to many Polyline 109 Polyline Instead of 1 Polyline
Dim vertices As List(Of LwPolyline.Vertex)
doc.Header.Version = ACadVersion.AC1018
doc.VPorts(VPort.DefaultName).ShowGrid = False
For Each vp As VPort In doc.VPorts
vp.ShowGrid = False
Next
Dim shapeActual = FeatureSet.Open(Path)
Dim FeatureQty As Int16 = shapeActual.Features.Count
' Dim plineLst As List(Of Polyline) = New List(Of Polyline)()
For Each feature As IFeature In shapeActual.Features
For i As Integer = 0 To feature.Geometry.NumGeometries - 1
For Each coord As Coordinate In feature.Geometry.GetGeometryN(i).Coordinates
Dim typ As DotSpatial.Data.FeatureType = feature.FeatureType
If typ = FeatureType.Line OrElse typ = FeatureType.Polygon Then
Dim LwPline = New LwPolyline()
For Each crd As Coordinate In feature.Geometry.Coordinates
vertices = New List(Of LwPolyline.Vertex)() From {
New LwPolyline.Vertex(New XY(crd.X, crd.Y))
For i44 As Integer = 0 To vertices.Count - 1
LwPline.Vertices.Add(vertices(i44))
LwPline.Layer = doc.Layers(Layer)
Next
Next
doc.Entities.Add(LwPline)
ElseIf typ = FeatureType.Point Then
ElseIf typ = FeatureType.MultiPoint Then
ElseIf typ = FeatureType.Unspecified Then
End If
Next
Next
Next
Regards
Sigster
You can debug DotSpace and ACadSharp separately to confirm which step changed 1 to 109.
