Code Red => AutoLISP (Vanilla / Visual) => Topic started by: cmwade77 on November 16, 2021, 07:29:31 PM
So, I have various drawings that use blocks that have weblinks in them, I need to make PDFs that do not include these weblinks using a LISP routine. No matter what I do, I can't seem to make it do what I want. Also, it needs to be able to be done through AcCoreConsole, so that brings its own limitations into the mix as well.
In Publish under publish options just turn off hyperlinks. That should do it.
Yes, I know how to do it manually, but I need to know how to do it from LISP and using AcCoreConsole. In other words with no dialog boxes involved.
I don't know the answer, but FYI Bluebeam can easily delete all links from a PDF.
