CAD Forums => CAD General => Topic started by: DIW_CADtech on May 30, 2014, 02:22:34 PM
Normally when i am using autocad I tend to select everything and then use the shift key and click to deselct..
however after I have embeded an image, rasterdesigntools are then loaded, and the shift key has no effect. :realmad:
Any idea if there is an alternate key, or a way to turn that shift key back into a deselect once RasterTools are loaded? :embarrassed:
I believe this is what your looking for.
Check your "_MAPIOPTIONS"
GENERAL TAB > "Shift+Left Click Image Select"
Uncheck this option if it's checked.
Nope.. ACAD doesn't recognize Mapioptions as a command.
Fire up Raster Tools
IOPTIONSPAGE > U > "User Preferences" Tab > Uncheck "Shift + Left click image select"
BuckoAk's the winner.. that did it...
thank you much.
WOOO HOOO..
been dealing with that headache for months.
:laugh:
