Code Red => .NET => Topic started by: surveyor_randy on May 30, 2014, 10:44:00 AM
This is a Civil 3D question.
I'm trying to use the Basecurve method of the surveyfigure object and it isn't there. I get a error message saying that "basecurve is not a member of Autodesk.AECC.Interop.Survey.AeccSurveyFigure"
Dim survFig As AeccSurveyFigure = TryCast(TR.GetObject(Res1.ObjectId, OpenMode.ForWrite), AeccSurveyFigure)
Dim baseCurve As Curve = survFig.Basecurve()
I'm referencing:
accoremgd
acdbmgd
acmgd
Autodesk.AEC.Interop.Base
Autodesk.AEC.Interop.UIBase
Autodesk.AECC.Interop.Roadway
Autodesk.AECC.Interop.UiRoadway
Autodesk.AECC.Interop.UiSurvey
What am I missing. I'm not an expert programmer and couldn't tell you the difference between COM and .NET. I'm sure one of you gurus will know right away what my issue is. I really appreciate any help someone can provide. Thanks guys!
BaseCurve is a property, you are using it like a method. This should work (although I don't speak VB too well):
I'm pretty sure you can do something like this, too (it works in C#, not sure of the context in VB):
Dim survFig As Curve = TryCast(TR.GetObject(Res1.ObjectId, OpenMode.ForWrite), Curve)
Oh, as I was changing that last line I realized you are casting the Figure as an Aecc object, which is COM, so will not work any way as BaseCurve is a property of the managed API SurveyFigure object.
Great! Thank you very much Jeff!
It seems I was missing references to AecBaseMgd.dll and AeccDBMgd.dll
You got me on the right track! :-)
