CAD Forums => Vertically Challenged => Land Lubber / Geographically Positioned => Topic started by: BlackBox on April 15, 2014, 03:34:07 PM
I have plenty of disk space as discussed in another thread, yet am repeatedly prompted by the 'max undo' message while modeling a moderately complex corridor. :|
Is there any way to increase this allocation, so that I am no longer prompted (or perhaps even prompted less often), without disabling undo, etc.?
TIA
what is your setting for ISAVEPERCENT?
and or UNDOCTL?
I have literally never encountered this issue myself.
However a anther guy I am working with did last month.
and or UNDOCTL?
ISAVEPERCENT == 0
UNDOCTL == 61 (Default)
... Nor had I (using Civil 3D 2011 & 2012), until I started using Civil 3D 2014.
Back in v2009, we kept getting weird undo errors. I started cleaning our temp folders of all the old undo/redo files. You can try this...
(defun c:CleanTemp nil
;; delete all UND* and RED* temp files
(foreach x (vl-directory-files (getvar 'tempprefix))
(if (wcmatch (strcase x) "UND*,RED*")
(vl-catch-all-apply 'vl-file-delete (list (strcat (getvar 'tempprefix) x)))
Actually, I did have a user complain about an undo error, but he encountered it several times before I came on. I told him to run the above command and he's never complained about the undo issue again.
I still find it strange that I've never experienced this issue with Civil 3D 2011, or 2012 :|... I'll plug that into AcadDoc.lsp and see if that doesn't help.
Thank you, kind Sir. :angel:
does this seem to be drawing specific? I've work on some jobs where this was a constant problem, but as I recall, it was limited to only some jobs/drawings/attached xrefs or drefs
Admittedly, this is only happening in a drawing that contains only the needed data to create a moderately complex, proposed roadway corridor.
That said, this model does contain more than others that I've done, as this was a vanilla AutoCAD drawing, drawn using Land Desktop 2005, and has no LDT database to import... Instead I've had to manually recreate each-and-every-single Alignment, Profile, Profile View, Assembly, etc. so that I can model the multiple roundabouts, and handful of intersections, before I even get to the grading of ponds, etc. for this adjoining proposed subdivision.
I've only been here a little more than 60 days, but so far most of my work in similar... It's one of the reasons the owners hired me, as their existing staff have IDS 2014 installed, and have been sent out for 3 days training, but don't use it (still using LDT 2005)... Hand drawing vertical profiles, scaling title blocks in paper space so that the viewport scale is 1:1, all sorts of nonsense.
The new server I'm ordering today, will present the opportunity for me to take LDT offline in short order, as I shall not be migrating the license(s) on the server, and all of our IDS 2014 installations are on each user's computer... All IDS 2014 licenses were installed prior to my being hired on, with exception of two, so I'm not really sure if I can/should change that then as well?
No problem. I just hope it helps. I'm quite sure that was the error he was receiving.
FWIW - I am still experiencing the undo message in that same model... The drawing file size is now more than 70MB, and I've only finished modeling the roadway corridor to the ROW. Now I'm starting to create the Feature lines, and grading to complete the lots, ponds, etc. :|
[vent]
I haven't worked on anything else really, as this particular project is a bleeping bleepety bleep bleep bleepety bleep mess. :realmad:
I cannot even use their linework to create the necessary C3D components without corrective steps... A few here or there is one thing... Lot lines do not properly intersect, edge of pavement in a roundabout that is called out as a specific radius in the plans, isn't and overlaps the outer circle of my corridor region that represents the interior & travel lane of my roundabout (so now my curb return and roundabout regions overlap instead of meet at the outer alignment).
Elevation labels are... Wait for it... Attribute Definitions, where they changed the TagString to be the elevation value, surrounded by a rectangle, sometimes accompanied by a line, and located inconsistently adjacent a hatched circle... That is inconsistently located 'somewhere' near the actual point of elevation.
Further, not all of the elevation labels are even in model space... Some are located in paper space layout, where the title block has been scale up such that the 1:50 scale D-size sheet has a viewport scale of 1:1, but only these four lots are labeled in paper space; the other 15 lot labels for the same sheet are in model space on the same layer, so I cannot even effectively XREF (once I programmatically change all of the ATTDEF to TEXT).
I had no idea this project was going to be SO much of a cluster bleepety bleep; I can honestly say that this 20 year veteran's CAD is the utter, and absolute worst I have ever seen in my limited experience... I am not looking forward to the uphill battle that awaits, in order to teach them how to properly use Civil 3D. :lol:
[/vent]
[vent]
[/vent]
And the worst part of that battle, they may resent you for trying to change the way they do things
no matter how bassackwards it really is 'to you'.
This would be a good time to call in an outside training resource, and look like the good guy.
Or tell them they are doing it wrong and be labelled the bad guy.
[vent]
[/vent]
I completely agree with Michael on the training. Even if it's only for a day, it reinforces your arguments.
FWIW -
That multi-day paid external training event has already come and gone prior to my arrival.
I was recruited by the owner's favorite designer (whom I briefly worked with at another company), as a direct result of their choosing to not use the skills they learned, and instead continue to use Land Desktop 2004 as vanilla AutoCAD (i.e., no vertical profiles, no surfaces, all hand drawn profiles, etc.).
The owner wasn't particularly interested in retaining this person before I was brought on... I'm happy to help those willing to learn, and will even learn some in the process; it's ultimately their rope.
sounds to me that the training was poor, if they didn't get the incentive to utilize the skills
the training should have imparted to them.
sometimes I function as much "coach" as educator
Likely just a bunch of OTB training. :-(
I'm preparing for two different groups right now.
Even the base material is similar, the types of projects they do, and client base they serve
are different enough that it is taking some time to prepare the lessons and test for purpose.
Most don't want to do this, without calling it customized and increasing the fee.
Your generous assessment is kind, but inaccurate, having personally worked with them over the past +/- 90 days.
There is a clear distinction between unfamiliarity, and unwillingness... The latter is both part of why I've been brought on, and one of the specific items I am attempting to help them overcome.
I predict you will be villanized, and eating lunch alone very often.
I am in a similar position here.
They have some practices that really need to be changed.
My challenge is to not upset them in the process of being that agent for change.
I know that all too well.
BB, does this drawing contain any Annotative hatches? If so, set their annotative setting to off and see if that brings the drawing into submission. There appears to be a bug with these in C3D2013 & 2014 (not sure about 2015). For more reading on this: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/UNDO-file-size/m-p/4354423#M210720
Thank you, Jeff... Unfortunately, there are no hatches, just an unintentionally bloated model... I didn't realize when I started I had to create every aspect of a C3D project.
No real way (that I know of) to export only Profile Views into this drawing, and their parent Alignment's into another, etc. without completely redoing the corridor. :|
export to XML
and or discrete use of data shortcut
