Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Pepe on March 09, 2011, 02:47:48 PM
Hi...
Does anybody knows where (and/or how) do this command saves the parameters defined, both in the actual session and option "save as"? :?
Thanks in advance.
Look for a file named “filter.nfl”, generally located in one of the support file directories.
It is a text file using fairly standard AutoLisp/Dxf filtering techniques.
I missed that one while searching... :oops:
Thank you very much, SEANT! (indeed... :-) )
