Code Red => .NET => Topic started by: Kerry on December 14, 2007, 11:16:53 PM
From my Saturday reading ..
public sealed class SymbolUtilityServices
Assembly: acdbmgd, Version=17.1.0.0
has a Method
public static ObjectId GetBlockModelSpaceId(Database databasePointer);
In the past , to open Modelspace for Write, I've used something like the following, in one of several variations
ObjectId objId = new ObjectId();
Database Db = HostApplicationServices.WorkingDatabase;
AcDb.TransactionManager Tm = Db.TransactionManager;
using (Transaction tr = Tm.StartTransaction())
BlockTable tb = (BlockTable)Tm.GetObject
(Db.BlockTableId, OpenMode.ForRead, false);
objId = ((BlockTableRecord)Tm.GetObject
(tb[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false)).AppendEntity(ent);
Tm.AddNewlyCreatedDBObject(entToWriteToDataBase, true);
tr.Commit();
however, using SymbolUtilityServices.GetBlockModelSpaceId seems a little easier ..
objId = ((BlockTableRecord)Tm.GetObject(AcDb.SymbolUtilityServices.GetBlockModelSpaceId(Db),
Tm.AddNewlyCreatedDBObject(ent, true);
tr.Commit();
edit for fatFingerSpelling
So, an Entity extension Class ( similar to previously posted by Daniel M )
// CodeHimBelongaKwb © Dec 2007
// D:\Development\Visual Studio 2008\CAD Projects\Sat1215\Sat1215\EntityExtensions.cs
using System;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
namespace Sat1215
public static partial class EntityExtensions
internal static ObjectId AddToModelSpace(this Entity ent)
tr.Commit();
return objId;
internal static ObjectId AddToModelSpace(this Entity ent , Database Db)
objId = ((BlockTableRecord)Tm.GetObject( AcDb.SymbolUtilityServices.GetBlockModelSpaceId(Db),
tr.Commit();
return objId;
and to Test it ....
// D:\Development\Visual Studio 2008\CAD Projects\Sat1215\Sat1215\Commands.cs
using System;
[assembly: CommandClass(typeof(Sat1215.Commands))]
namespace Sat1215
class Commands
[CommandMethod("test")]
static public void cmdtest()
Line ln = new Line(new Point3d(0, 0, 0), new Point3d(100, 100, 0));
ln.AddToModelSpace();
ln = new Line(new Point3d(100, 100, 0), new Point3d(100, 200, 0));
ln.AddToModelSpace(Db);
The partial classes are irrelevant to the use of the Method, I'm just playing with them here..
I'll be getting back into C# down the road, so I'm thanking you, Daniel ... in advance, for surely this stuff will be useful to me.
and a piccy of some of the OTHER Methods and Properties available
Though, thinking of extension classes ...
This is pretty efficient AND cool ..
internal static ObjectId ModelSpaceId(this Database Db)
return SymbolUtilityServices.GetBlockModelSpaceId(Db);
Piccy Added ..
This is what I ended up with ..
just need to add XML comments so that the Intellisense displays the comments.
internal static ObjectId ModelSpaceId(this Database db)
return SymbolUtilityServices.GetBlockModelSpaceId(db);
return ent.AddToModelSpace(HostApplicationServices.WorkingDatabase);
internal static ObjectId AddToModelSpace(this Entity ent, Database db)
Acdb.TransactionManager tm = db.TransactionManager;
using (Transaction tr = tm.StartTransaction())
objId = ((BlockTableRecord)tm.GetObject(db.ModelSpaceId(),
tm.AddNewlyCreatedDBObject(ent, true);
tr.Commit();
return objId;
Great stuff Kerry! FYI in the 2006 API the GetBlockModelSpaceId() & GetBlockPaperSpaceId()
methods are not static, so people using this API will need to create a new instance of the class.
It might be wise to use the other method to get the Space id for compatibility.
Thanks for the heads-up about the 2006 API.
.. the old backward compatibility issue ... yuk !
I'm developing for AC2007, 2008, 2009 so I think I'll ignore 2006 issues.
This is the Paperspace stuff using SymbolUtilityServices
/// <summary>
/// Gets and return the PaperSpace ObjectId.
/// </summary>
/// <param name="db">Database to use</param>
/// <returns>The PaperSpace ObjectId of the Database parameter</returns>
internal static ObjectId PaperSpaceId(this Database db)
return SymbolUtilityServices.GetBlockPaperSpaceId(db);
internal static ObjectId AddToPaperSpace(this Entity ent)
return ent.AddToPaperSpace(HostApplicationServices.WorkingDatabase);
internal static ObjectId AddToPaperSpace(this Entity ent, Database db)
ObjectId objId;
objId = ((BlockTableRecord)tm.GetObject(db.PaperSpaceId(),
tr.Commit();
return objId;
.. and this is the associated Intellisence comments from the compiled XML comment. ( for anyone who hasn't made use of the feature :-) )
The Database object already has a CurrentSpaceId getter, so when Writing to the Current Space we don't need to concoct our own.
internal static ObjectId AddToCurrentSpace(this Entity ent)
return ent.AddToCurrentSpace(HostApplicationServices.WorkingDatabase);
internal static ObjectId AddToCurrentSpace(this Entity ent, Database db)
ObjectId objId;
objId = ((BlockTableRecord) tm.GetObject(db.CurrentSpaceId,
tr.Commit();
return objId;
How did I miss this class!?! <shakes head> Nice find Kerry...you just keep on reading ;)
Cheers,
Glenn.
>>>>. ..you just keep on reading ;)
Cheers,
Glenn.
I certainly will :)
