Author Topic: [XDrX-PlugIn(152)] Find overlapping dimension text and mark it with a cloud  (Read 154 times)
xdcad
(defun c:xdtb_dimchkoverlaps ( / box ents len len1 overlaps pl ss x)
  (defun _make-cloud ()
    (setq pl (xdrx-polyline-make box t))
    (xdrx-curve->cloud pl (/ len1 1.1) 0.35 (/ len1 4.0) 0.0)
    (xdrx-setpropertyvalue (entlast) "color" 2)
    (xdrx-block-make
      (strcat "xd_dim_overlap_mark"
      (strcase (xdrx-string-rand 6) t)
      (entlast)
      (trans (xd::geom:get9pt (entlast) 5) 1 0)
      t
  (xdrx-begin)
  (if (and (setq ss (xdrx-ssget
      (xdrx-string-multilanguage
"\n选择查询的标注对象<退出>:"
"\nSelect the Dimension object of the query<Exit>:"
      '((0 . "dim*"))
   (setq overlaps (xd::dim:textoverlaps ss))
      (mapcar '(lambda (x)
(setq ents (car x)
       box  (cadr x)
       len  (/ (distance (nth 0 box) (nth 1 box)) 4.0)
       len1 (distance (nth 0 box) (nth 3 box))
       box  (xdrx-points-offset (/ len1 3.5) box)
(_make-cloud)
      overlaps
  (xdrx-end)
https://github.com/xdcad
http://bbs.xdcad.net
