Author Topic: Reading and Saving Attribute values. ala DBX - VL Version ..  (Read 1783 times)
Reading and Saving Attribute values. ala DBX..
... The Lispy Version.
http://www.theswamp.org/index.php?topic=29992.msg355647#msg355647
Thought some may find it usefull or interesting.
« Last Edit: August 23, 2009, 10:16:43 PM by Kerry Brown »
Joe Burke
Re: Reading and Saving Attribute values. ala DBX - VL Version ..
« Reply #1 on: August 24, 2009, 08:28:45 AM »
Hi Kerry,
Just curious, are you content with the fact this (vla-get-textstring Att) will include formatting codes as opposed to how the text appears on screen?
Given a standard text type attribute you might get this: "text %%Ustring 224%%U". Given a multiline attribute in 2008 or later, the formatting codes can be as complex as those which apply to an mtext object in 2008.
Joe Burke
« Reply #3 on: August 24, 2009, 08:54:47 AM »
I thought you might mention that Joe...    ;-)
Lee,
Similar issues are on my mind while I try to update my SwapText routine to include support for swapping fields and multiline attributes.
« Reply #4 on: August 24, 2009, 09:08:01 AM »
I can imagine... 1 step forward and 3 steps back it seems  :|
Since the advent of mAttribs I've had to bulk up my routines substantially, and as for "unformatting" fields - that is a task in itself....    :-(
