Author Topic: units question..  (Read 3756 times)
Andrea
units question..
« on: October 21, 2005, 03:40:27 PM »
Hi all..
I have this..
(setq val1 0.25)
(setq val2 (rtos val1))   ;;returns  "0.2500"
(setq val2 (rtos val1 2 8))   ;;returns  "0.25000000"
(setq val2 (rtos val1 2 0))   ;;returns  "0"
so the question is...
how to get "0.25" without using (rtos val1 2 2)  ??
Keep smile...
Crank
Re: units question..
« Reply #1 on: October 21, 2005, 04:17:31 PM »
DIMZIN = 8
Andrea
« Reply #2 on: October 21, 2005, 04:20:04 PM »
DIMZIN ??
why using DIM variables ??
do I nee to change also LUPREC ??
Naaaahhh !!
Please can you explain exctly what DIMZIN affect ??
thanks.
Keep smile...
Serge J. Gianolla
« Reply #3 on: October 21, 2005, 04:21:40 PM »
Since you work in decimal, check DIMZIN = 8
But if all you want to have is Val2 equal to Val1 then (setq Val2 Val1) or am i missing something!
Serge J. Gianolla
« Reply #4 on: October 21, 2005, 04:23:10 PM »
Rats, got beaten by Crank :-D
deegeecees
« Reply #5 on: October 21, 2005, 04:27:05 PM »
From the AutoCAD Developers Help:
vl-string-right-trim Function
Removes the specified characters from the end of a string
(vl-string-right-trim character-set string)
Arguments
character-set
A string listing the characters to be removed.
string
The string to be stripped of character-set.
Return Values
A string containing a substring of string with all trailing characters in character-set removed.
Examples
_$ (vl-string-right-trim " \t\n" " STR \n\t ")
" STR"
_$ (vl-string-right-trim "1356789" "3CPO is not R2D267891")
"3CPO is not R2D2"
_$ (vl-string-right-trim " " "There are too many spaces here      ")
"There are too many spaces here"
Andrea
« Reply #6 on: October 21, 2005, 04:41:12 PM »
Hey !! Hi, Serge..long time no talk..
in fact i need to compare ..(if (= val1 val2) ...
so if val1 is "0.25" and val2 is "0.25000000"..the result was nil.
sur i can do... (if (= (read val1) (read val2))....
but I dont want to convert for after reconvert again..see ?
thanks.
Keep smile...
Serge J. Gianolla
« Reply #7 on: October 21, 2005, 04:55:51 PM »
I see, but when you are comparing with the read function, you are not converting and having to re-convert, comparison is done on the fly without changing the values from strings to reals! Capisci?
Andrea
« Reply #8 on: October 22, 2005, 11:36:11 PM »
I see Serge...
But I need also to put the result in a dialog box...
see ? :-o
Keep smile...
Serge J. Gianolla
« Reply #9 on: October 23, 2005, 02:46:32 AM »
OK, it appears that my good pal Andrea has a bit of hard time getting my explanation, so I'll try differently! Please, people who get upset when they don't see english words [you know who you are :evil:] look somewhere else or keep your remarks for yourselves, thank you.
Andrea,
Quand tu compares les 2 values a l'aide de READ, il n'y a pas de conversion qui intervient. Tes 2 valeurs restent des chaines de characteres, et peuvent donc etre passees a ta boite de dialogue apres. Ca va mieux comme explications? Tu comprends la comprenance? :lmao:
P.S: I was after ODCL2, but never mind. I started with ver 3, and so far so good. Ciao
Andrea
« Reply #10 on: October 25, 2005, 05:20:14 PM »
Serge,...
Maybe i'm not clear with my explaination to...
I don't have a problem to compare...
I have proble to show the result..
because I need to re-convert in string...
see ?
Keep smile...
« Reply #11 on: October 27, 2005, 09:35:11 AM »
Perhaps this.
(setq rval1 0.25)
(setq rval2 0.25)
(setq $val1 (rtos rval1 2))
(setq $val2 (rtos rval2 2))
(setq $val1 (vl-string-right-trim "0" $val1))
(setq $val2 (vl-string-right-trim "0" $val2))
(= $val1 $val2)
0.25
0.25
"0.25000"
"0.25000"
"0.25"
"0.25"
T
_$
