Author Topic: Unique List of Points  (Read 3181 times)
mailmaverick
« on: March 28, 2014, 06:38:08 AM »
I have a list containing various points in form of ( (x1 y1 z1) (x2 y2 z2) (x3 y3 z3).......)
Certain points in the list are same. I want to get unique list of points.
How to do that ?
gile
  • Marseille, France
Re: Unique List of Points
« Reply #1 on: March 28, 2014, 06:58:07 AM »
Try this:
  1. (defun gc:distinct (l)
  2.   (if l
  3.     (cons (car l) (gc:distinct (vl-remove (car l) l)))
  4.   )
  5. )
(gc:distinct thePointList)
mailmaverick
« Reply #2 on: March 28, 2014, 07:07:31 AM »
Excellent !!!!!
Now can we add some fuzz factor into this ?
I mean all points shall be considered duplicate if their distance is less than 0.00001 m and any one of them shall be kept in the final list.
irneb
« Reply #3 on: March 28, 2014, 07:24:38 AM »
Not very efficient:
  1. (defun lst:unique (lst fuzz / result)
  2.   (while lst
  3.     (if (not (vl-some '(lambda (item) (equal item (car lst) fuzz)) result))
  4.       (setq result (cons (car lst) result)))
  5.     (setq lst (cdr lst)))
  6.   (reverse result))
gile
  • Marseille, France
« Reply #4 on: March 28, 2014, 08:01:35 AM »
  1. (defun gc:distinctFuzz (lst fuzz)
  2.   (if lst
  3.     (cons (car lst)
  4.           (gc:distinct
  5.             (vl-remove-if '(lambda (x) (equal x (car lst) fuzz)) lst)
  6.           )
  7.     )
  8.   )
  9. )
(gc:distinctFuzz thePointList 0.00001)
irneb
« Reply #5 on: March 28, 2014, 08:18:49 AM »
  2.   (if lst
  3.     (cons (car lst)
  4.           (gc:distinctFuzz
  6.             fuzz
  7.           )
  8.     )
  9.   )
  10. )
FIFY :-D
gile
  • Marseille, France
« Reply #6 on: March 28, 2014, 08:30:54 AM »
Thanks Irne.
mailmaverick
« Reply #7 on: March 28, 2014, 12:10:29 PM »
Thanks to all. Problem solved.
« Reply #8 on: March 29, 2014, 02:07:52 PM »
mailmaverick
« Reply #9 on: March 31, 2014, 03:55:43 AM »
I have a list (called LISTA) containing various points in form of ( (x1 y1 z1) (x2 y2 z2) (x3 y3 z3).......).
I want following functionalities :-
1.) How to get a new list (LISTB) of those points which are present in list only once. Note that this is not unique function as posted earlier in this post. All those points in the list LISTA whose distance is less than fuzz value must be considered as one point.
2.) How to get a new list (LISTC) of those points which are present in list only twice along with fuzz factor.
3.) How to compare that a point (P) in form of (xn yn zn) is present in (member of) list LISTA along with fuzz factor ?
Thanks.
How to do that ?
irneb
« Reply #10 on: March 31, 2014, 08:53:17 AM »
Have you tried the codes in this thread and Lee's page (which describes what they do)? They all literally take one list, then extract those values so the new list contains unique values.
What you're after is a way to get only the values which do not have duplicates. A very similar approach would work here:
Using the recursive method:
  • Start with the 1st item in the list - stop if the list is empty.
  • Check if it is inside the rest of the list (use the vl-some method as per my iterative approach).
  • If not (i.e. unique), then cons it into the result of calling the same function using the rest of the list.
  • Else (if duplicate found) only call the same function on the rest of the list.
Using the iterative approach:
  • Start with the 1st item in the list.
  • If not (i.e. unique), then cons it into the result.
  • No else portion.
  • Change the list to only contain the rest of the list and repeat the loop.
  • After loop, return the result variable reversed to get the values in the original order.
Doing it for the duplicate counter is a bit more complicated. You'd need another list which counts how many times a particular value was found in the list. Then extract only those with the count the same number as specified.
irneb
« Reply #11 on: March 31, 2014, 09:07:48 AM »
For this I'd suggest getting a fuzzy version of assoc.
Iterative version
  1. (defun assoc-fuzz (key lst fuzz / found)
  2.   (while (and (setq found (car lst)) (not (equal key (car found) fuzz)))
  3.     (setq lst (cdr lst)))
  4.   found)
Recursive version:
  1. (defun assoc-fuzz (key lst fuzz)
  2.   (cond ((equal key (caar lst) fuzz) (car lst))
  3.         (lst (assoc-fuzz key (cdr lst) fuzz))))
irneb
« Reply #12 on: March 31, 2014, 09:24:23 AM »
E.g. a general purpose one:
  1. (defun group-duplicates-fuzz (lst fuzz / result found)
  2.   (foreach item lst
  3.     (if (setq found (assoc-fuzz item result))
  4.       (setq result (subst (cons item found) found result))
  5.       (setq result (cons (list item) result))))
  6.   result)
  7.
  8. (defun find-duplicates-fuzz (lst fuzz count)
  9.   (vl-remove-if-not '(lambda (item) (= (length item) count))
  10.     (group-duplicates-fuzz lst fuzz)))
Say you want all points which are duplicated once (i.e. 2 copies of in the list) with a fuzz-factor of 0.5:
  1. (find-duplicates-fuzz lst 0.5 2)
fixo
« Reply #13 on: March 31, 2014, 10:13:17 AM »
Possible suitable such function to retrieve unique and identical pairs:
(defun uique_pairs  (lst fuzz / data result)
  (while (car lst)
    (if (and (setq pair (vl-remove-if-not
  lst))
     (>= (length pair)2))
      (setq result (append result (list (list (car pair) (cadr pair))))))
    (setq lst (vl-member-if '(lambda (a) (not (member a pair))) lst)))
  (reverse
    (while (setq pair (car result))
      (setq result (vl-remove pair result)
            data (cons pair data))))
  data
;;usage (setq pairs (uique_pairs lst1 0.0001))
