Code Red => AutoLISP (Vanilla / Visual) => Topic started by: risfuk on February 26, 2009, 12:05:42 PM
Hi all
am new to this site + all the lisp stuff.....i have a project to do...where i have to change close to 2000 blocks
The blocks need to be updated in the means of a few lines deleted which is on a different layer + some of the attributes taken out
Once this is done I would like to update the blocks within working drawings
Is this possible by using VB + lisp files to make this automatic
all help would be great thanks
I'm sure it's possible with both languages, as I know it can be done with Lisp by itself. It wouldn't be too hard to redefine a block within multiple drawings, but once attributes are involved, it is a little harder, as they are separate entities from the block, but still linked to the block.
How much experience do you have with writing lisp?
Welcome to theSwamp.
Thanks for the welcome :-) i only started out with lisp but had quite experience with VB...mmm i did think the update with attributes would be the tricky part of it..... have had a quick play today and manged to update the block its self but with the attributes i had to run a attsync comand which had to be done manually...
manually? you're using vba right? did you try ThisDrawing.SendCommand ("ATTSYNC" ...)?
If you are just removing attributes, and not adding them, then that isn't too hard, as long as you know the ' Tag ' property. Just search the drawing for said block, then step through the attribute collection comparing the ' Tag ', and if it matches then delete the attribute. No need to use the command ' attsync '.
Has anyone got any good examples in Vb then? or a good know of a good site to get some from cheers :-D
bump
