Author Topic: copy files to the right folder  (Read 2239 times)
Humbertogo
« on: October 31, 2007, 07:32:59 AM »
i have a number of folders this are project names
the folders name are for example 100_250 that main
that in this folder are project files from 100 to 250
25_99
100_250
But know i need to one project in the right folder for example
i need to copy project number 30 and 175 to the right folder
how to do that?
Atook
  • AKA Tim
Re: copy files to the right folder
« Reply #1 on: October 31, 2007, 01:11:20 PM »
I'm not understanding you, perhaps you could post a screenshot of your folder tree?
Humbertogo
« Reply #2 on: October 31, 2007, 03:11:54 PM »
another way like this
'project 30
 If 30 > 25 And 99 > 30  Or 30 = 25 Or 99 = 30 Then
in to folde 25_99
'project 175
 If 175 > 100 And 250 > 175  Or 175 = 100 Or 250 = 175 Then
in to folde 100_250
folder tree
Projects
- 25_99
-100_250
« Last Edit: October 31, 2007, 03:15:10 PM by Humbertogo »
Bob Wahr
« Reply #3 on: October 31, 2007, 03:50:27 PM »
This should give you a start
Sub test()
Dim objFS As Object
Dim objDrive As Object
Dim objFldrs As Object
Dim objFldr As Object
Set objFS = CreateObject("Scripting.FileSystemObject")
Set objDrive = objFS.GetFolder("C:\")
Set objFldrs = objDrive.subfolders
For Each objFldr In objFldrs
    If objFldr.Name < 100 Then
        objFldr.MoveFolder objFldr.Path, "c:\25_99\" & objFldr.Name
    ElseIf objFldr.Name < 251 Then
        objFldr.MoveFolder objFldr.Path, "c:\100_250\" & objFldr.Name
    End If
Next objFldr
Not tested but should be pretty close.
Bob Wahr
« Reply #4 on: October 31, 2007, 04:06:51 PM »
Just noticed the name of the thread didn't match my answer.  You'll want to use the CopyFolder method instead of MoveFolder if copying is what you want to do.
Bob Wahr
« Reply #5 on: November 05, 2007, 02:39:19 PM »
I'm guessing by the lack of follow up that I was either close enough that you got it to work or far enough that you gave up.
ML
« Reply #6 on: November 05, 2007, 06:39:10 PM »
Hi Bob
He did say copy but otherwise, it lookslike you nailed it.
The FSO object is very helpful
Bryco
« Reply #7 on: November 05, 2007, 08:12:34 PM »
Since the string "11" >"100" it's best if you convert the file names to integers before doing your check.
if isnumeric(filename) then ifile=cint(filename)
ML
« Reply #8 on: November 06, 2007, 09:41:40 AM »
So you are saying, he should declare objFldr as Integer?
Dim objFldr As Integer
Is so, that makes sense
However, the  objFldr.Path is a string
I noticed with VBSripting language, data types aren't really used much, at least what I have seen.
When I use or bring scripting code into VBA, I do try to assign the correct data types instead of just using object or variable for the nec. reasons and to avoid using Variant too much.
ML
« Reply #9 on: November 06, 2007, 09:42:38 AM »
I see, I think the function isnumeric will look at a string of text and grab the numeric values?
Bryco
« Reply #10 on: November 06, 2007, 01:01:24 PM »
IsNumeric returns True if the entire expression is recognized as a number; otherwise, it returns False.
It doesn't grab the numeric values
ML
« Reply #11 on: November 06, 2007, 01:08:20 PM »
Ahhhhh cool
Thanks Bry!
