Author Topic: Compile and run snippet code (without AutoCAD)  (Read 2011 times)
vegbruiser
« on: May 22, 2012, 10:59:02 AM »
I saw this and thought others might find it useful:
http://rextester.com
It allows you to compile and run .NET code without having to fire up (and wait for!!) AutoCAD. :evil:
They also have a Regex tester.
Here's an example I've made use of today: http://rextester.com/rundotnet?code=OQTZE85773 since I've not really used Regular Expressions before.
  • Custom Title
Re: Compile and run snippet code (without AutoCAD)
« Reply #1 on: May 22, 2012, 11:19:05 AM »
took a while but I found it.
might help *shrug*
http://www.theswamp.org/index.php?topic=11979.0
TheMaster
« Reply #2 on: May 22, 2012, 03:21:01 PM »
LINQPad (http://www.linqpad.net) can also compile and run snippets or complete programs, without the sandbox restrictions, but like rextester, also doesn't support running AutoCAD-dependent code.
MexicanCustard
« Reply #3 on: May 23, 2012, 07:17:03 AM »
Check out Gallio Icarus.  Doesn't run independent of AutoCAD but will give same testing functionality within AutoCAD and will auto launch app within AutoCAD.
