Author Topic: global variable?  (Read 1967 times)
MexicanCustard
global variable?
« on: June 27, 2011, 08:23:06 PM »
What's the best way to keep track of things between method calls?
I.E. I'm isolating layers on one method call "IsolateNestedEntities". Then I want to revert the layer's on/off back to pre-isolation "UnIsolateNestedEntities"?
Currently I'm using a global variable,  will this stay the same if the user changes active documents during the session or is a new instance started for each document?
Re: global variable?
« Reply #1 on: June 27, 2011, 08:36:32 PM »
If is per document storage you're looking for,  have a look at Autodesk.AutoCAD.ApplicationServices.Document.UserData
kaefer
« Reply #2 on: June 28, 2011, 04:23:38 AM »
Why do I need the UserData hashtable at all when I can instantiate arbitrary data structures in the constructor of the class containing instance command methods? I.e.
    public class MyCommandClass
        MyData myData = null;
        MyCommandClass() {
            mydata = new MyData();
        [CommandMethod("InstanceCommand")]
        public void InstanceCommand() {
            // There's a MyData instance for each Document the command runs in
kaefer
« Reply #3 on: June 28, 2011, 06:08:34 AM »
Answering my own question: I need it if I want to know what the UserData for the other Documents is, of course.
« Reply #4 on: June 28, 2011, 07:00:08 AM »
Also, I prefer static command methods over non, there is a bit less overhead when invoking.
MexicanCustard
« Reply #5 on: June 28, 2011, 08:14:26 AM »
Thanks guys! That answers my question.
Doing a search on UserData I found this:
http://through-the-interface.typepad.com/through_the_interface/2006/10/perdocument_dat_1.html
