Anyone else ever get this message while freezing/turning off layers?
Command:
Command: layoff
Initializing...
Nested error trapping used incorrectly.
Resetting nesting index to 1.
Select an object on the layer to be turned off or [Options/Undo]:
bad function: <Selection set: 2ba>
Command:
Command:
Command: layfrz
Select an object on the layer to be frozen or [Options/Undo]:
Nothing selected.
Command:
Command: *Cancel*
Its happened a few times. If I close AutoCAD it works fine.
Thanks.
Pete
