Author Topic: PDF file Help!!  (Read 2692 times)
AVCAD
PDF file Help!!
« on: December 02, 2004, 03:28:46 PM »
Dones anyone know of a better way to put Cutsheets (PDF files) into a CAD drawing. Other then turning the PDF to a Tiff or Jpg file. This really doesnt work that well the text gets jumbled and funcky things like to happen.
Help is appreciated!
Thanks!
M-dub
PDF file Help!!
« Reply #1 on: December 02, 2004, 03:34:39 PM »
I've never done it, but I know it's been discussed here before...
http://theswamp.org/phpBB2/viewtopic.php?t=2362&highlight=pdf+dwg
for one...
HTH ;)
M-dub
PDF file Help!!
« Reply #2 on: December 02, 2004, 03:54:22 PM »
AVCAD
PDF file Help!!
« Reply #3 on: December 03, 2004, 10:17:31 AM »
No...these PDF's are not Drawings files they are actual Cut sheets of equipment.
Like for a JBL control 25 speaker...they have specs and what not on them. My boss want to have these on the drawings instead of a seperate document set. this way we can have the Spec documents with the drawings.
I tried turning them into Jpegs and Tif and Targa files but they dont print out right. The text is all jumbled and for some reason the image likes to shrink when it gets printed.
Any other suggestions....
THanks!
Craig
PDF file Help!!
« Reply #4 on: December 03, 2004, 10:33:05 AM »
What we do is place the image in paperspace instead of modelspace. We had a similar problem until we moved them to PS.
AVCAD
PDF file Help!!
« Reply #5 on: December 03, 2004, 12:39:10 PM »
will try...sound intresting..wonder why the problem happens though...maybe is a viewport thing.
Will try the suggestion though
...what do you use Jpg or Tiff images..
PDF file Help!!
« Reply #6 on: December 03, 2004, 12:58:35 PM »
Adobe Illustrator will take a PDF and write it to a dwg.
Craig
PDF file Help!!
« Reply #7 on: December 03, 2004, 01:19:34 PM »
We use TIFF images for those type applications
M-dub
PDF file Help!!
« Reply #8 on: December 03, 2004, 01:52:11 PM »
And us...CAL (GP4) files.
