Author Topic: Visibility state not visable  (Read 5833 times)
David Hall
  • Automatic Duh Generator
« on: July 15, 2009, 12:25:45 PM »
OK, what I mean by this is can you create a visibility state(s) and NOT have the ability to change them manually in the drawing?  I tried making the visibility state marker invisible in current state, but that didnt work.  Where I am going with this, is I would like to duplicate some ADT functionallity where you have a 2D view in plan, and it switches to a 3d view when your viewpoint moves from 0,0,1.
Any ideas?
James Cannon
Re: Visibility state not visable
« Reply #1 on: July 15, 2009, 12:45:15 PM »
Wow, that's a good idear.
Doesn't changing the # of grips to ZERO eliminate it enough, or am I on the wrong track?
David Hall
« Reply #2 on: July 15, 2009, 12:58:20 PM »
I haven't tried that, ummmmm, how do you do that?
David Hall
« Reply #3 on: July 15, 2009, 01:05:13 PM »
Sweet, that worked perfectly!!!!!  Thanks James!
Matt__W
  • I like my water diluted.
« Reply #4 on: July 15, 2009, 01:18:09 PM »
You can still get around it by changing the vis-state in the properties palette.
Autodesk Expert Elite
David Hall
« Reply #5 on: July 15, 2009, 03:07:30 PM »
Yes, but I am not expecting the bumps on the log to look there
David Hall
« Reply #6 on: July 15, 2009, 03:46:01 PM »
For those interested, here is a sample of my 2d-3d block.  The best way to see it is to set an iso view, grip the dwg and use properties to switch the visibility states.
James Cannon
« Reply #7 on: July 15, 2009, 03:53:04 PM »
Pretty wicked.  How're you going to accomplish the toggling based on view?
artisteroi
« Reply #8 on: July 15, 2009, 04:05:47 PM »
nicely done. I thought I was the only one working with 3d dynamics
David Hall
« Reply #9 on: July 15, 2009, 04:22:17 PM »
I am revamping my Substation design tool for the 3rd time, and I thought I would add this functionallity.  Currently, I am only doing it through the push of one of my buttons.  If a user changes the view w/o using the correct button, nothing happens.  I want to add the ability to have a reactor that senses the vpoint change.  The problem I have not looked into yet is Shift-Wheel rotate.  Does that update vpoint right away or is it hidden somewhere.
David Hall
« Reply #10 on: July 15, 2009, 04:22:43 PM »
What are you doing?  Arch or otherwise?
James Cannon
« Reply #11 on: July 15, 2009, 04:24:33 PM »
What sort of functions have you managed to execute with dynamic blocks in 3d?
David Hall
« Reply #12 on: July 15, 2009, 05:19:05 PM »
This is my first, and yes I realize you were not talking to me
