Author Topic: Dim Mode !!?  (Read 11151 times)
Dim Mode !!?
« Reply #30 on: February 24, 2005, 07:10:06 PM »
Take a look at the vba module Keith posted .......You can set the layer to whatever you please before ANY command.
http://theswamp.org/phpBB2/viewtopic.php?p=33933#33933
I have a dimension layer set before:
dimaligned
dimangular
dimbaseline
dimcenter
dimcontinue
dimdiameter
dimlinear
dimordinate
dimradius
qdim
dim
and the layer will be set back after the command is done or you cancel out.
Ron
Andrea
Dim Mode !!?
« Reply #31 on: February 24, 2005, 10:13:27 PM »
what about
QLEADER or LEADER ??
Keep smile...
Dim Mode !!?
« Reply #32 on: February 25, 2005, 11:24:03 AM »
what about
We put those on a "leader" layer.....
Like I said before....ANY COMMAND can have a layer created before you run it.
If (CommandName = "dim") Then
  CLayer = ThisDrawing.GetVariable("CLAYER")
  Set XrefLay = ThisDrawing.Layers.Add("dimension")
  XrefLay.color = acWhite
  ThisDrawing.SetVariable "CLAYER", "dimension"
 End If
All you have to do is create another section with the appropriate command and layer.
Ron
Andrea
Dim Mode !!?
« Reply #33 on: February 27, 2005, 06:00:11 PM »
Quote from: ronjonp
what about
 End If
Ron
Ok..ronjonp..
first...thanks for all your answer..
but i think i need help...because l'm not very familar with VBA in AutoCAD.. :oops:
How to get this routine to work ?
Keep smile...
Andrea
Dim Mode !!?
« Reply #34 on: February 27, 2005, 06:44:15 PM »
Quote from: ronjonp
dimaligned
dimangular
dimbaseline
dimcenter
dimcontinue
dimdiameter
dimlinear
dimordinate
dimradius
qdim
dim
Ron
Ronjonp...
see the
I have made some tests..
Keep smile...
Andrea
Dim Mode !!?
« Reply #35 on: February 28, 2005, 09:23:29 AM »
rnew reply...
also..I need to make DIM command before dimensionning..
the
dimaligned
dimangular
dimbaseline
dimcenter
dimcontinue
dimdiameter
dimlinear
dimordinate
dimradius
qdim
dim
command not working in our office...maybe because we have AutoCAD (French release) even with the "underscore" before the command _
Keep smile...
PDJ
Dim Mode !!?
« Reply #36 on: February 28, 2005, 02:17:02 PM »
Andrea, here's something I've been using for about 15 years now:
(setq cl  (getvar "clayer")        ;current layer
            cc  (getvar "cecolor")       ;current color
            tln (cdr (assoc 8 el))       ;text layer name
            tc  (cdr (assoc 62 el))      ;text color
Then to return back to the previous values:
(if (/= cl tln)(command "LAYER" "S" cl ""))
           (if (/= cc tc)(command "COLOR" cc))
Andrea
Dim Mode !!?
« Reply #37 on: February 28, 2005, 04:35:23 PM »
Quote from: PDJ
PDJ...
I think the code is not complete...
need the "el" variable..
also, if "el" is a selected entity...
this is not what i need.
I only need to detect the DIM mode.
Keep smile...
