Author Topic: Challenge : Regular Polygon  (Read 7689 times)
« on: November 12, 2006, 12:53:19 PM »
Challenge:
Create a subroutine to Draw / Entmake a regular polygon.
Given:
  • Center point
  • No. of Sides >2
  • Size - Radius Value
  • Inscribe or Circumscribe Flag
gile
  • Marseille, France
Re: Challenge : Regular Polygon
« Reply #1 on: November 12, 2006, 01:59:03 PM »
Here's my contribution :
;; Center point -> cen
;; No. of Sides >2 -> nb
;; Size - Radius Value -> rad
;; Inscribe or Circumscribe Flag -> flag
(defun draw_polygon (cen nb rad flag / zdir elv n lst)
  (setq zdir (trans '(0 0 1) 1 0 T)
elv  (- (caddr cen) (caddr (trans '(0 0 0) 0 1)))
cen  (list (car cen) (cadr cen) 0.0)
n    nb
  (if (= flag "Circumscribe")
    (setq rad (/ rad (cos (/ pi nb))))
  (repeat nb
    (setq lst (cons (polar cen (* (/ (* 2 pi) nb) (setq n (1- n))) rad) lst))
  (entmake
    (append
      (list '(0 . "LWPOLYLINE")
    '(100 . "AcDbEntity")
    '(100 . "AcDbPolyline")
    (cons 90 nb)
    '(70 . 1)
    (cons 38 elv)
    (cons 210 zdir)
      (mapcar '(lambda (pt) (cons 10 (trans pt 1 zdir))) lst)
EDIT: add a test function.
(defun c:test (/ cen nb rad flag)
  (setq cen (getpoint "\nCenter: ")
nb  (getint "\nNumber of sides: ")
rad (getdist cen "\Radius: ")
  (initget 1 "Inscribe Circumscribe")
  (setq
    flag (getkword "\nInscribe or Circumscribe ? [Inscribe/Circumscribe]: ")
  (draw_polygon cen nb rad flag)
« Last Edit: November 12, 2006, 04:29:01 PM by gile »
Fatty
« Reply #2 on: November 12, 2006, 02:09:59 PM »
As always I/m late again :)
(defun _entmake_polygon_eX (pt no rad flag / a da cnt pt pts rad x y)
  (setq da  (/ (* 2 pi) no)
rad (if flag ;Inscribe
      rad
      (* rad (cos (/ pi no))));Circumscribe
cnt 0
a   0
  (while (< cnt no)
    (setq a (* da cnt))
    (setq x (* rad (cos a))
  y (* rad (sin a))
    (setq pts (cons (list x y) pts))
    (setq cnt (1+ cnt))
  (setq pts (mapcar (function (lambda (x)
(mapcar '+ x pt)
    (reverse pts)
  (entmake
    (append
      (list
(cons 0 "LWPOLYLINE")
(cons 100 "AcDbEntity")
(cons 100 "AcDbPolyline")
(cons 90 no)
(cons 70 1)
(cons 43 0.0)
  (cons 10 x)
      pts
;TesT :
(_entmake_polygon_eX '(0 0) 9 42.545 nil)
(_entmake_polygon_eX '(0 0) 9 42.545 t)
~'J'~
« Reply #3 on: November 12, 2006, 05:17:24 PM »
Great job Guy's.
Gile your's works as expected.
Fatty your Inscribe is as expected but the circumscribe is not.
With circumscribe the apothem and radius entered should be the same.
« Last Edit: November 14, 2006, 12:18:40 PM by CAB »
Fatty
« Reply #4 on: November 12, 2006, 05:45:09 PM »
Great job Guy's.
Gile your's workes as expected.
Thank you, Alan,
here is edited version, I don't know why I have used multiple
instead of divide, sorry :|
rad (if flag
      (/ rad (cos (/ pi no))) ;Circumscribe
      rad ;Inscribe
cnt 0
a   0
  (while (< cnt no)
    (setq a (* da cnt))
  y (* rad (sin a))
    (setq cnt (1+ cnt))
(mapcar '+ x pt)
    (reverse pts)
  (entmake
    (append
      (list
(cons 90 no)
(cons 70 1)
(cons 43 0.0)
  (cons 10 x)
      pts
;TesT :
(_entmake_polygon_eX '(0 0) 8 50.0 nil);Inscribe
(_entmake_polygon_eX '(0 0) 8 50.0 t);Circumscribe
here is another one, where I have to used the segment length as a size
(defun _entmake_polygonSeg (pt no segm / a da cnt pt pts rad x y)
rad (/ segm 2 (sin (/ pi no)))
cnt 0
a   0
  (while (< cnt no)
    (setq a (* da cnt))
  y (* rad (sin a))
    (setq cnt (1+ cnt))
(mapcar '+ x pt)
    (reverse pts)
  (entmake
    (append
      (list
(cons 90 no)
(cons 70 1)
(cons 43 0.0)
  (cons 10 x)
      pts
;TesT :
(_entmake_polygonSeg '(0 0) 8 50.0)
~'J'~
« Reply #5 on: November 12, 2006, 07:46:34 PM »
Good job Fatty & a nice extra routine.
« Reply #6 on: November 12, 2006, 07:47:00 PM »
OK, here is a level 2 challenge.
Create the polygon so that one side is parallel to the x axis.
gile
  • Marseille, France
« Reply #7 on: November 13, 2006, 01:10:48 AM »
For the level 2 challenge:
n    nb
  (if (= 1 (rem nb 2))
    (setq ang (/ pi 2))
    (setq ang (+ (/ pi 2) (/ pi nb)))
  (repeat nb
    (setq lst (cons (polar cen (+ ang (* (/ (* 2 pi) nb) (setq n (1- n)))) rad) lst))
  (entmake
    (append
    (cons 90 nb)
    '(70 . 1)
    (cons 38 elv)
    (cons 210 zdir)
  (setq
Fatty
« Reply #8 on: November 13, 2006, 02:59:18 AM »
First side and X axis are parallel:
(defun _entmake_polygon_XAxis (pt no rad flag / a da cnt pt pts rad x y)
rad (if flag
      rad ;Inscribe
cnt 0
sa   (- (* 1.5 pi)(/ pi no))
a 0
  (while (< cnt no)
    (setq a (+ sa (* da cnt)))
  y (* rad (sin a))
    (setq cnt (1+ cnt))
(mapcar '+ x pt)
    (reverse pts)
  (entmake
    (append
      (list
(cons 90 no)
(cons 70 1)
(cons 43 0.0)
  (cons 10 x)
      pts
;TesT :
(_entmake_polygon_XAxis '(0 0) 9 50.0 nil);Inscribe
(_entmake_polygon_XAxis '(0 0) 9 50.0 t);Circumscribe
First side and Y axis are parallel:
(defun _entmake_polygon_YAxis (pt no rad flag / a da cnt pt pts rad x y)
rad (if flag
      rad ;Inscribe
cnt 0
sa   (- pi (/ pi no))
a 0
  (while (< cnt no)
  y (* rad (sin a))
    (setq cnt (1+ cnt))
(mapcar '+ x pt)
    (reverse pts)
  (entmake
    (append
      (list
(cons 90 no)
(cons 70 1)
(cons 43 0.0)
  (cons 10 x)
      pts
;TesT :
(_entmake_polygon_YAxis '(0 0) 7 50.0 nil);Inscribe
(_entmake_polygon_YAxis '(0 0) 7 50.0 t);Circumscribe
~'J'~
« Reply #9 on: November 13, 2006, 07:43:27 AM »
Excellent solutions. You guy's are too fast. :)
sinc
« Reply #10 on: November 13, 2006, 08:00:51 AM »
...and nobody's using (command "_polygon")...  :-)
« Reply #11 on: November 13, 2006, 09:02:36 AM »
Here is my revised version.
I must say I benefited form the fine examples already posted. :)
My first attempts were clumsy by comparison.
(defun mk_polygon (pt n rad ci? / ang ang1 lst)
  (and ci? (setq rad (/ rad (cos (/ pi n)))))
  (setq ang  (/ pi (/ n 2.))
        ang1 (+ (* pi 1.5) (/ ang 2))
  (while (>= (setq n (1- n)) 0)
    (setq lst (cons (cons 10 (polar pt (+ ang1 (* ang n)) rad)) lst))
  (entmake
    (append (list (cons 0 "LWPOLYLINE")
                  (cons 90 (length lst))
                  (cons 70 1)
                  (cons 43 0.0)
                  (cons 38 0.0)
                  (cons 39 0.0)
            lst
  (initget "Inscribe Circumscribe")
  (setq flag
           ((getkword "\nType ? [Inscribe/Circumscribe]: <Inscribe>"))
           ("Inscribe")))
  (mk_polygon cen nb rad (= flag "Circumscribe"))
« Reply #12 on: November 13, 2006, 09:13:57 AM »
Gile,
You seem to have a very good understanding of the coordinate system & the use of trans.
It would be beneficial to me and a number of folks here if you would share that knowledge in a
separate post of even an article on the subject.
Especially,  "when you need it" and what commands & function need what type of trans.
I know that is a lot to ask as that type of post is very time consuming on your part, so if
it not something you have time for I'll / we will keep learning from the code you post.
Thanks for your examples.
« Reply #13 on: November 13, 2006, 10:24:22 AM »
Gile,
Just to clarify, I am talking about an "Over View" of the application of trans.  :-)
« Reply #14 on: November 14, 2006, 10:25:50 AM »
This version provide the ability to align a specific side with the x or y axis.
;;  CAB version2  11/15/2006
;;  Arguments:
;;  pt    center point
;;  n     number of sides
;;  rad   radius of circle
;;  ci?   t/nil Cercumscribe/Inscribe on the circle
;;  align string, side with xTop or xBottom or yRight or yLeft
;;  lay   string, layer name
;;  clr   color number
(defun mk_polygon (pt n rad ci? align lay clr / ang ang1 lst)
  (setq ang  (/ pi (/ n 2.0))
        align (strcase align))
    ((= align "XBOTTOM")
     (setq ang1 (+ (* pi 1.5) (/ ang 2)))
    ((= align "XTOP")
     (setq ang1 (+ (* pi 1.5) (/ ang 2) pi))
    ((= align "YRIGHT")
     (setq ang1 (+ (/ ang 2)))
    ((= align "YLEFT")
     (setq ang1 (+ (/ ang 2) pi))
    (t (setq ang1 0))
  (entmake
                      (cons 8 lay)
                      (cons 70 1) ; 0= open  1= closed
                      (cons 43 0.0)
                      (cons 38 0.0)
                      (cons 39 0.0)
                      (cons 62 clr) ; color bylayer
                lst
(defun c:test2(/ wait ss)
  (defun wait (prm) (getstring (if prm prm "\nPress enter to continue")))
  (setq ss (ssadd))
  (mk_polygon '(0.0 0.0 0.0) 5 5 t "xTop" "0" 1)
  (ssadd (entlast) ss)
  (wait "\nxTop")
  (mk_polygon '(0.0 0.0 0.0) 5 5 t "xBottom" "0" 2)
  (wait "\nxBottom")
  (mk_polygon '(0.0 0.0 0.0) 5 5 nIL "yRight" "0" 3)
  (wait  "\nyRight")
  (mk_polygon '(0.0 0.0 0.0) 5 5 nil "yLeft" "0" 4)
  (wait  "\nyLeft")
  (mk_polygon '(0.0 0.0 0.0) 5 5 nil "xy45R" "0" 5)
  (wait  "\nxy45R")
  (mk_polygon '(0.0 0.0 0.0) 5 5 nil "xy45L" "0" 6)
  (wait  "\nxy45L")
  (command "._erase" ss "")
« Last Edit: November 14, 2006, 02:17:55 PM by CAB »
