Hi! I want to know if its possible to find number and names of block tags in drawing, without selection. Example, I have a block called CONS_C1 with tags NUMBER, HEIGHT, LLC, EEC.
I'd like to, just by knowing name of the block, find out number of tags, and names if possible, but the number is mainly what I want.
I tried the following
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq testblock (vla-item (vla-get-blocks doc) "CONS_C1"))
And with
(vla-get-count testblock)
I get some something (number of tags+1), but not sure if its the best way to do what I need.
Any help welcome, thanks!
