Author Topic: 2d Spline through Many X y Points  (Read 1328 times)
SDETERS
« on: February 20, 2009, 03:58:58 PM »
I have an Excel sheet that has about two hundred x y coordinates
What is the best way to import the x,y coordinates into Autocad and draw a Spline through them points?
I did a search I did not find any thing on this   Please point me in the correct direction if this has been visited before
Shane.
FengK
Re: 2d Spline through Many X y Points
« Reply #1 on: February 20, 2009, 06:05:36 PM »
similar questions (if not exactly the same) must have been asked before. i suppose in your excel sheet, each line has one point? you can save the excel file as a .csv file, then you can read its content with lisp to get a list of points. do you know a little bit of lisp? if so, this should be helpful.
« Last Edit: February 20, 2009, 06:29:58 PM by xycadd »
wannabe
« Reply #2 on: February 21, 2009, 08:39:12 AM »
Try looking at scripts first, if you're not too well up on LISP. It may be a shorter process in many respects.
