(entget (namedobjdict))=>( (-1 . <Entity name: cae4640>) (0 . "DICTIONARY") (5 . "28") (330 . <Entity name: ca992b8>) (100 . "AcDbDictionary") (281 . 1) (3 . "ACAD_ASSOCPERSSUBENTMANAGER") (350 . <Entity name: cae5cc8>) (3 . "ACAD_BACKGROUND") (350 . <Entity name: cae5908>) (3 . "ACAD_CIP_PREVIOUS_PRODUCT_INFO") (350 . <Entity name: cae6108>) (3 . "ACAD_COLOR") (350 . <Entity name: cae4a80>) (3 . "ACAD_DETAILVIEWSTYLE") (350 . <Entity name: caea048>) (3 . "ACAD_FLATSHOT") (350 . <Entity name: cae64c8>) (3 . "ACAD_GROUP") (350 . <Entity name: cabe6d0>) (3 . "ACAD_IMAGE_DICT") (350 . <Entity name: cae5808>) (3 . "ACAD_IMAGE_VARS") (350 . <Entity name: cae5888>) (3 . "ACAD_LAYOUT") (350 . <Entity name: cae4900>) (3 . "ACAD_MATERIAL") (350 . <Entity name: cae4a40>) (3 . "ACAD_MLEADERSTYLE") (350 . <Entity name: cae51c8>) (3 . "ACAD_MLINESTYLE") (350 . <Entity name: cabe710>) (3 . "ACAD_PERSUBENTMGR") (350 . <Entity name: cae58c8>) (3 . "ACAD_PLOTSETTINGS") (350 . <Entity name: cae4940>) (3 . "ACAD_PLOTSTYLENAME") (350 . <Entity name: cae4880>) (3 . "ACAD_RENDER_SETTINGS") (350 . <Entity name: cae9f48>) (3 . "ACAD_SCALELIST") (350 . <Entity name: caea448>) (3 . "ACAD_SECTIONVIEWSTYLE") (350 . <Entity name: caea088>) (3 . "ACAD_TABLESTYLE") (350 . <Entity name: cae5108>) (3 . "ACAD_VISUALSTYLE") (350 . <Entity name: cae4c80>) (3 . "ACAD_WIPEOUT_VARS") (350 . <Entity name: cae5f08>) (3 . "AcDbVariableDictionary") (350 . <Entity name: cae49c0>) (3 . "AcDsDecomposeData") (350 . <Entity name: caeb4c8>) (3 . "AEC_CLASSIFICATION_SYSTEM_DEFS") (350 . <Entity name: cae5588>) (3 . "AEC_PROPERTY_SET_DEFS") (350 . <Entity name: cae5248>))
Wblocking ('Entire drawing') also works.
Dynamic blocks US 7860691 B2 EstrattoTools and techniques for creating and editing a master block definition for a dynamic block, and manipulating a block instantiation of a dynamic block are described. One or more data structures that can be used to implement a dynamic block feature are described
So the block does seem to be the culprit.Maybe removing the draworder (AcDbSortentsTable) from the block definition will help?Code - Auto/Visual Lisp: [Select](vla-delete (vla-getextensiondictionary (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) "A$C6E506268" ) ))
I get nil (Bricscad) then in AutoCAD nothing happen.
Quote from: Marc'Antonio Alessi on December 10, 2015, 03:54:47 PMI get nil (Bricscad) then in AutoCAD nothing happen. (vla-delete) always returns nil. So that is to be expected.If wblocking combined with the removal of the draworder does not work then I can think of only one other solution: SAVEASR12. Note that wblocking is effective in the sense that the file size is drastically reduced (from 3.3 Mb to 60 Kb).
Have you tried exploding it in BricsCAD, then copy and pasting it into a new drawing in AutoCAD?ETA: Nevermind, that didn't work either. This one is strange, even more normal cleanup routines for dealing with bricsCAD files aren't fixing this one.
;IAcadHatch 5160c160 : TeighaX Interface of an area fill consisting of a pattern of lines;; Property values :;; Application (RO) = #<VLA-OBJECT IAcadApplication 0000000019DC5B00>; Area (RO) = 1221.06531409624; AssociativeHatch = 0; color = 256; Database (RO) = #<VLA-OBJECT IAcadDatabase 00000000514BB148>; Document (RO) = #<VLA-OBJECT IAcadDocument 00000000514C2AB8>; Elevation = 9.09494701772928e-013; EntityName (RO) = "AcDbHatch"; EntityType (RO) = NIL; GradientAngle = 2.0943951023932; GradientCentered = -1; GradientColor1 = NIL; GradientColor2 = NIL; GradientName = "LINEAR"; Handle (RO) = "8080F"; HasExtensionDictionary (RO) = 0; HatchObjectType = 0; HatchStyle = 1; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 00000000514BC1D8>; ISOPenWidth = -1; Layer = "TRATTEGGIO"; Linetype = "BYLAYER"; LinetypeScale = 1.0; Lineweight = -1; Material = "ByLayer"; Normal = (0.0 0.0 1.0); NumberOfLoops (RO) = 1; ObjectID (RO) = 546829792; ObjectID32 (RO) = 546829792; ObjectName (RO) = "AcDbHatch"; Origin = (0.0 0.0); OwnerID (RO) = 546412976; OwnerID32 (RO) = 546412976; PatternAngle = 2.0943951023932; PatternDouble = 0; PatternName (RO) = "GOST_WOOD"; PatternScale = 8.0; PatternSpace = 8.0; PatternType (RO) = 1; PlotStyleName = "ByLayer"; TrueColor = #<VLA-OBJECT IAcadAcCmColor 00000000195C9798>; Visible = -1;; Methods supported :;; AppendInnerLoop (1); AppendOuterLoop (1); ArrayPolar (3); ArrayRectangular (6); Copy (); Delete (); Erase (); Evaluate (); GetBoundingBox (2); GetExtensionDictionary (); GetLoopAt (2); GetXData (3); Highlight (1); InsertLoopAt (3); IntersectWith (2); Mirror (2); Mirror3D (3); Move (2); Rotate (2); Rotate3D (3); ScaleEntity (2); SetPattern (2); SetXData (2); TransformBy (1); Update ()(-1 . <Entity name: 2097f5e0>) (0 . "HATCH") (5 . "8080F") (330 . <Entity name: 209199b0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "TRATTEGGIO") (100 . "AcDbHatch") (10 0.0 0.0 9.09494701772928e-013) (210 0.0 0.0 1.0) (2 . "GOST_WOOD") (70 . 0) (71 . 0) (91 . 1) (92 . 5) (93 . 7) (72 . 4) (94 . 4) (73 . 0) (74 . 0) (95 . 10) (96 . 5) (40 . 8.66605524692759e-015) (40 . 8.66605524692759e-015) (40 . 8.66605524692759e-015) (40 . 8.66605524692759e-015) (40 . 8.66605524692759e-015) (40 . 15.3604729579) (40 . 15.3604729579) (40 . 15.3604729579) (40 . 15.3604729579) (40 . 15.3604729579) (10 27625.761678308 11970.3073935879 0.0) (10 27627.3956176882 11971.4455596444 0.0) (10 27628.7105224969 11972.6019625011 0.0) (10 27629.6470908795 11973.7350579276 0.0) (10 27630.1852955288 11974.8057212035 0.0) (97 . 0) (72 . 4) (94 . 5) (73 . 0) (74 . 0) (95 . 21) (96 . 15) (40 . 0.0) (40 . 0.0) (40 . 0.0) (40 . 0.0) (40 . 0.0) (40 . 0.0) (40 . 7.19664967541) (40 . 7.19664967541) (40 . 7.19664967541) (40 . 12.7361893378) (40 . 12.7361893378) (40 . 12.7361893378) (40 . 19.9881698388) (40 . 19.9881698388) (40 . 19.9881698388) (40 . 30.9811372399) (40 . 30.9811372399) (40 . 30.9811372399) (40 . 30.9811372399) (40 . 30.9811372399) (40 . 30.9811372399) (10 27630.1852955288 11974.8057212035 0.0) (10 27629.9514567419 11976.405815139 0.0) (10 27629.724864137 11977.9563255617 0.0) (10 27629.4643734572 11979.7387909117 0.0) (10 27629.0519150466 11982.5611293544 0.0) (10 27628.5958866549 11985.6816051148 0.0) (10 27628.3939288876 11987.0635460771 0.0) (10 27627.9735686082 11989.9399548221 0.0) (10 27627.4700806643 11993.3851831283 0.0) (10 27627.199944863 11995.2336474505 0.0) (10 27626.6055047114 11999.3012364801 0.0) (10 27625.8091286848 12004.750616636 0.0) (10 27625.399206085 12007.5556032561 0.0) (10 27625.0436280408 12009.9887251496 0.0) (10 27624.6211643708 12012.8795268219 0.0) (97 . 0) (72 . 4) (94 . 5) (73 . 0) (74 . 0) (95 . 12) (96 . 6) (40 . 40.2918835887) (40 . 40.2918835887) (40 . 40.2918835887) (40 . 40.2918835887) (40 . 40.2918835887) (40 . 40.2918835887) (40 . 51.1532513847) (40 . 51.1532513847) (40 . 51.1532513847) (40 . 51.1532513847) (40 . 51.1532513847) (40 . 51.1532513847) (10 27624.6211643708 12012.8795268219 0.0) (10 27621.792737246 12011.2465336601 0.0) (10 27618.9643101213 12009.6135404982 0.0) (10 27616.1358829966 12007.9805473363 0.0) (10 27613.3074558718 12006.3475541745 0.0) (10 27610.4790287471 12004.7145610126 0.0) (97 . 0) (72 . 4) (94 . 5) (73 . 0) (74 . 0) (95 . 12) (96 . 6) (40 . 169.839335841) (40 . 169.839335841) (40 . 169.839335841) (40 . 169.839335841) (40 . 169.839335841) (40 . 169.839335841) (40 . 180.700703637) (40 . 180.700703637) (40 . 180.700703637) (40 . 180.700703637) (40 . 180.700703637) (40 . 180.700703637) (10 27610.4790287471 12004.7145610126 0.0) (10 27607.6506016223 12003.0815678508 0.0) (10 27604.8221744976 12001.4485746889 0.0) (10 27601.9937473728 11999.8155815271 0.0) (10 27599.1653202481 11998.1825883652 0.0) (10 27596.3368931233 11996.5495952034 0.0) (97 . 0) (72 . 4) (94 . 5) (73 . 0) (74 . 0) (95 . 12) (96 . 6) (40 . 147.521650494) (40 . 147.521650494) (40 . 147.521650494) (40 . 147.521650494) (40 . 147.521650494) (40 . 147.521650494) (40 . 169.839335841) (40 . 169.839335841) (40 . 169.839335841) (40 . 169.839335841) (40 . 169.839335841) (40 . 169.839335841) (10 27596.3368931233 11996.5495952034 0.0) (10 27596.3368931233 11990.1482620089 0.0) (10 27596.3368931233 11983.7469288144 0.0) (10 27596.3368931233 11977.3455956199 0.0) (10 27596.3368931233 11970.9442624255 0.0) (10 27596.3368931233 11964.542929231 0.0) (97 . 0) (72 . 4) (94 . 5) (73 . 0) (74 . 0) (95 . 12) (96 . 6) (40 . 1.28772369648847e-013) (40 . 1.28772369648847e-013) (40 . 1.28772369648847e-013) (40 . 1.28772369648847e-013) (40 . 1.28772369648847e-013) (40 . 1.28772369648847e-013) (40 . 31.5614303123) (40 . 31.5614303123) (40 . 31.5614303123) (40 . 31.5614303123) (40 . 31.5614303123) (40 . 31.5614303123) (10 27596.3368931233 11964.542929231 0.0) (10 27599.3286093758 11964.0921137851 0.0) (10 27603.0655166295 11964.0755553403 0.0) (10 27607.3224801509 11964.5287303519 0.0) (10 27611.7567478733 11965.4151484516 0.0) (10 27616.0431599051 11966.6407553942 0.0) (97 . 0) (72 . 4) (94 . 4) (73 . 0) (74 . 0) (95 . 10) (96 . 5) (40 . 0.0) (40 . 0.0) (40 . 0.0) (40 . 0.0) (40 . 0.0) (40 . 15.3604729588) (40 . 15.3604729588) (40 . 15.3604729588) (40 . 15.3604729588) (40 . 15.3604729588) (10 27616.0431599051 11966.6407553942 0.0) (10 27618.6508251572 11967.3863609527 0.0) (10 27621.2005420448 11968.2660732655 0.0) (10 27623.5972259307 11969.2525571408 0.0) (10 27625.761678308 11970.3073935879 0.0) (97 . 0) (97 . 0) (75 . 1) (76 . 1) (52 . 2.0943951023932) (41 . 8.0) (77 . 0) (78 . 3) (53 . 3.66519142918809) (43 . 11036.5378236968) (44 . 3895.28475605179) (45 . -24.0) (46 . 41.5692193816531) (79 . 2) (49 . 80.0) (49 . -16.0) (53 . 3.66519142918809) (43 . 11042.3942301573) (44 . 3917.14116251234) (45 . -24.0) (46 . 41.5692193816531) (79 . 4) (49 . 48.0) (49 . -12.0) (49 . 24.0) (49 . -12.0) (53 . 3.66519142918809) (43 . 11055.1788398482) (44 . 3942.99756897289) (45 . -24.0) (46 . 41.5692193816531) (79 . 2) (49 . 80.0) (49 . -16.0) (47 . 1.19191486519316) (98 . 2) (10 27662.7636273437 11863.4509197533 0.0) (10 27662.7636273437 11863.4509197533 0.0) (-3 ( "_APP169C2" (1070 . 5) ) ( "_APP169C3" (1070 . 2) ) ( "ACAD" (1010 0.0 0.0 0.0) ) ))
