Author Topic: Get Layer Object from LayerName  (Read 6122 times)
Re: Get Layer Object from LayerName
« Reply #15 on: April 02, 2014, 04:45:32 PM »
I love the way you make people work for their knowledge, Kerry. I know it's benefited me over the years.
Nah, I'm just a nasty bastard who enjoys inflicting pain.
BlackBox
« Reply #16 on: April 02, 2014, 04:54:04 PM »
Example
Note that throws an error if the layer doesn't exist, so you might have to wrap it inside a vl-catch-all-apply.
FWIW -
The Add() Method will yield an existing, or create a new LayerTableRecord for the LayerName (string) passed, which is great for reactors that set a specific layer current prior to a given command execution, etc.
For the OP's situation though, the Item() Method is perfectly fine, given that the string passed is from a selected entity.
Cheers
« Reply #17 on: April 02, 2014, 04:58:21 PM »
< .. >  but i want to use the vla- method.
mailmaverick,
When did you change your mind about what you wanted ?
1.2 seconds time difference for 25,000 iterations is miniscule.
I probably spend longer than that every 5 minutes finding a key on the keyboard.
Just to be fair , what happens is you run each of those routines on a drawing which doesn't contain the layer you want ?
alanjt
  • Standby for witty remark...
« Reply #18 on: April 02, 2014, 05:12:35 PM »
lol. Well, then I enjoy watching you annoying the hell out of everyone.  :-P
Dropbox
« Reply #19 on: April 02, 2014, 05:18:39 PM »
Cheers
I didn't know that (must have missed the memo) . If so, all the rules change.
BlackBox
« Reply #20 on: April 02, 2014, 05:22:23 PM »
Cheers
I must have confused two different threads, regarding the selected entity part.  :-D
