Author Topic: cons + eval  (Read 1309 times)
kruuger
cons + eval
« on: March 09, 2017, 09:01:15 AM »
hi
not sure how to properly type the subject but here is the issue
pseudo code which i want to execute.
we have subroutine _sum
than list of dotted pairs lst
now i want to go thru this list (assoc) and look for SearchFor.
if founded than eval correct _sum
(defun _sum (a b) (+ a b))
(setq lst
  (list
    (cons "One"   '(_sum 1 1))
    (cons "Two"   '(_sum 2 2))
    (cons "Three" '(_sum 3 3))
(setq SearchFor "Two")
(if (setq res (assoc SearchFor lst))
  (ok so (eval (cdr res)) to run (_sum 2 2))
  (wrong)
hope it is clear
thanks
kruuger
VovKa
  • Ukraine
Re: cons + eval
« Reply #1 on: March 09, 2017, 09:13:44 AM »
what is the question?
Grrr1337
Re: cons + eval
« Reply #2 on: March 09, 2017, 09:18:18 AM »
I think this is what you're asking:
  1. (defun _sum (a b) (+ a b))
  2.
  3. (setq lst
  4.   (list
  5.     (cons "One"   '(_sum 1 1))
  6.     (cons "Two"   '(_sum 2 2))
  7.     (cons "Three" '(_sum 3 3))
  8.   )
  9. )
  10.
  11. (setq SearchFor "Two")
  12.
  13.   (eval (cdr (assoc SearchFor lst)))
  14.   (princ "\nWrong.")
  15. ); or
or access the item as a symbol (lazy way):
  1. (or
  2.   (eval
  3.     (cdr
  4.       (assoc 'Two '( (One _sum 1 1) (Two _sum 2 2) (Three _sum 3 3) ) )
  5.     )
  6.   )
  7.   (princ "\nWrong")
  8. );or
(apply ''((a b c)(a b c))
vevo.bg
Re: cons + eval
« Reply #3 on: March 09, 2017, 12:37:46 PM »
Since the list does not contain variable data, the entire list may be quoted as a literal e.g.:
  1. (defun _sum ( a b ) (+ a b))
  2.
  3. (setq lst
  4.    '(
  5.         ("One"   _sum 1 1)
  6.         ("Two"   _sum 2 2)
  7.         ("Three" _sum 3 3)
  8.     )
  9. )
  10. (if (setq expr (cdr (assoc "Two" lst)))
  11.     (eval expr)
  12.     (princ "\nNot found.")
  13. )
Alternatively:
  2.
  3. (setq lst
  4.    '(
  5.         ("One"   1 1)
  6.         ("Two"   2 2)
  7.         ("Three" 3 3)
  8.     )
  9. )
  10. (if (setq args (cdr (assoc "Two" lst)))
  11.     (apply '_sum args)
  13. )
kruuger
Re: cons + eval
« Reply #4 on: March 09, 2017, 02:52:16 PM »
omg  :uglystupid2:  not sure why i expect cons this format to work with assoc:
("Two" . _sum 2 2)
and stop testing routine my routine. it looks like all was almost done.
thanks guys, all works fine.
