Author Topic: How to disable edit_box when popup_list item is selected?  (Read 3600 times)
Brick_top
« on: October 08, 2014, 04:38:17 AM »
Hi there I have a popup_list and an edit_box.
and I would like to disable the edit_box when a certain popup_list item is selected.
problem is I can't figure out the way to do it.
I know it is related to the (mode_tile) function
thanks
kpblc
Re: How to disable edit_box when popup_list item is selected?
« Reply #1 on: October 08, 2014, 04:47:30 AM »
(mode_tile <Key> 0) ;; enables <Key> control
(mode_tile <Key> 1) ;; disables <Key> control
What the question is? You can't write callback function? Please show your code and dcl
Sorry for my English.
Brick_top
« Reply #2 on: October 08, 2014, 04:58:02 AM »
I start the list in the popup list with this
(start_list "info_lst" 3)
   (mapcar 'add_list info_lst)
   (end_list)
the list might contain different number of items
 ("Nova" "Info 1" "Info 2")
I also have an edit_box with the key "inf2"
I want to have it greyed out whenever I don't have the item "Nova" in the popup_list selected.
Brick_top
« Reply #3 on: October 08, 2014, 05:01:24 AM »
I tried doing this but with no luck
(defun greyt (info_lstr)
     (if (= "0" info_lstr)
       (mode_tile "inf2" 0)
       (mode_tile "inf2" 1)
      );if
    );defun greyt
(action_tile "info_lst" "(greyt info_lstr)")
 (setq info_lstr (get_tile "info_lst"))
      );if
    );defun greyt
I think I solved it! this line was missing -> (setq info_lstr (get_tile "info_lst"))
« Last Edit: October 08, 2014, 05:26:14 AM by Brick_top »
« Reply #4 on: October 08, 2014, 06:16:09 AM »
Brick_top.
< .. > Please show your code and dcl
This sort of request is not made because we like typing  .. there is a reason for it !!
7 times out of 10 putting together and testing a succinct sample to demonstrate the problem will help resolve the issue even before you post your question..
Not doing so makes us ( well, me anyway) wonder why we should bother helping someone who won't help themselves.
succinct:
(especially of something written or spoken) briefly and clearly expressed.
Characterized by clear, precise expression in few words;
« Last Edit: October 08, 2014, 06:27:47 AM by Kerry »
Brick_top
« Reply #5 on: October 08, 2014, 06:17:53 AM »
thanks kerry, I understand that.
I guess I wrongly assumed that my request was something standard so I didn't need to post my code.
« Reply #6 on: October 08, 2014, 06:25:05 AM »
I know what you are saying ; but you will find you'll get a better quality of response if you are seen to make the effort. AS it was 'someone' ( well, several someones) would need to build their own sample to test and prove a solution.
Regarding your solution:
I can't see how that setq will resolve your problem as originally posted ... mainly because I can't imagine what your code looked like.
Nor can anyone else who potentially finds this thread while searching for a similar issue.
Regards,
roy_043
  • BricsCAD 18
« Reply #7 on: October 08, 2014, 06:47:51 AM »
This should accomplish the same:
(defun greyt ()
  (mode_tile "inf2" (if (= "0" (get_tile "info_lst")) 0 1))
(action_tile "info_lst" "(greyt)")
And this:
(defun greyt ()
  (mode_tile "inf2" (if (= "0" $value) 0 1))
Brick_top
« Reply #8 on: October 08, 2014, 07:14:50 AM »
thanks! fortunately that makes perfect sense, I'll keep that in mind whenever I post.
Regards,
I tried many things from some webpages but don't remember right now as I deleted them.
I'm going to try to explain my last effort and what I think that setq line solved.
;;; this is the version of code I thought would work
;here I wanted to enable the edit_box "inf2"
;whenever the item "0" of the popup_list "info_lst" was selected
     (if (= "0" info_lstr) ;info_lstr was defined before in the code in this function:
                           ;   (defun ad2 ()
                           ;>>>>>>>(setq info_lstr (get_tile "info_lst")) "info_lst" is the key of the popup list
                           ;    );ad2
     );if
);defun greyt
;as I understand it the problem with this ideia was that the value of the popup list
;to be checked for disabling the edit_box was only retrieved when exiting the dialog
;in this line bellow, so the function greyt couldn't check the value.
(action_tile "accept" "(setq ddiag 2)(ad2)(done_dialog)");note the call for the (ad2) function
;that is why I added the (setq info_lstr (get_tile "info_lst")) to the greyt function
  (setq info_lstr (get_tile "info_lst")) ;<- <- <- <- <-
      );if
  );defun greyt
;so that whenever I use the "info_lst" popup_list the function greyt is
;called to check which item is selected to disable or enable the edit_box
I hope this can help someone, I tried to be as succint as I could. At least I tried my best
Brick_top
« Reply #9 on: October 08, 2014, 07:16:22 AM »
(defun greyt ()
And this:
(defun greyt ()
thanks roy your solution is much more elegant
